changing tire size in the PCM - Ford Truck Enthusiasts Forums
Old 10-22-2014, 06:47 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 05-15-2012, 07:59 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
has anyone had the dealer change their tire size for them? say from 34 (stock) to 35 or such?
Old 05-15-2012, 08:27 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I tried, if that counts.
I'm unsure of the exact options but the tech I worked with tried available 18 inch rim sizes.
All except factory for 3.31 ratio and 18 inch rims threw a CEL.
In addition any 20 inch rim size threw a CEL because you can't buy 20 inch rims with a 3.31 ratio.
My dealer told me if I could find out the exact setting that works to bring it back and they'll change it for me but we gave up for now.
Old 05-15-2012, 08:29 PM
btw i have the 20" option (275 65 20's) and 3.55 axle
Old 05-15-2012, 09:54 PM
ninerM1000's Avatar
ninerM1000 ninerM1000 is offline
ninerM1000 is starting off with a positive reputation.
Are you asking for the speedo? I ran a 325/60/R20 duratrac for winter and my speedo was bang on. Checked it with a portable gps. Thinking they must read a little slow with stock tires.
Old 05-15-2012, 10:06 PM
Fontana Fontana is offline
Fontana is gaining momentum as a positive member of FTE.Fontana is gaining momentum as a positive member of FTE.
Quote:
Did you use that size tire on the stock 20" wheels? No lift or spacer?
Old 05-15-2012, 11:03 PM
Andrew010's Avatar
Andrew010 Andrew010 is online now
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
Computer won't accept any tire size larger than 34" w/o throwing a CEL. Makes absolutely no sense at all but that's how it is. Falls in the same stupid category as the TPMS adjustment issues. Not sure wtf Ford was thinking, or wasn't thinking....
Old 05-15-2012, 11:15 PM
so andrew, what size tires do you have with that lift. i know youve put pics up before, but could you throw a few up in here too? im lookin at 295 65 20 trails, on a 4 inch lift. wonder what kind of effects im to expect
Old 05-15-2012, 11:33 PM
my996duc1's Avatar
my996duc1 my996duc1 is offline
my996duc1 is gaining momentum as a positive member of FTE.my996duc1 is gaining momentum as a positive member of FTE.
My speedo was off with stock tires - 275/70R18 (33.2").
I switched out to some larger tires - 285/75R18 (34.8").
My speedo is now spot on with GPS.
If you don't have a portable GPS you can download a free app on your cell/smart phone to check your speed.
It is called "GPS Speedo" on the Android system.
_
Old 05-15-2012, 11:59 PM
Andrew010's Avatar
My tires are 35x12.50 but actually measure just over 34" tall once mounted. My stock tires actually measured about 33" tall and were sized at 34". My tuner will adjust tire size up to 34" which is almost spot on for my 35" tires. My speedo is off about 1 mph (slow)
Old 05-16-2012, 12:02 AM
I think the 295 65 20 is just a tad bigger. And the reason im likely going that route is for the size and load rating and psi. Nittos size chart is super useful
Old 05-16-2012, 12:17 AM
jetpilot2's Avatar
jetpilot2 jetpilot2 is online now
jetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to beholdjetpilot2 is a splendid one to behold
Quote:
According to the calculator, 295/65/20 = 35.1" Diameter
Old 05-16-2012, 09:43 PM
ninerM1000's Avatar
Quote:
I ran the 325's on stock 2010 F350 rims that I got on kijiji cheap. I have a 4.5" lift.
Old 05-17-2012, 05:16 PM
That is the exact tire option I'm interested in. Nitto Trail Grappler
Please let us know what you chose to do. I don't know if we are forced to buy different wheels (I think you do) and what option you chose. I would like a black wheel preferably with some deep well affect that is made in USA. I am not interested in doing a lift so I'm very curious how you go about it.
Old 05-17-2012, 05:21 PM
the nitto 295 65 20 is the biggest 20in tire they have, also with the highest load rating and psi rating. thats the route im goin. may end up putting it on the stock rim tho for now. with a 4 inch lift tho
Old 05-17-2012, 06:27 PM
Andrew010's Avatar
They make a 37" tire.
FORScan for Tire Size changes RainDesert 2017 Super Duty 8 12-16-2016 11:46 AM
Tires Fyrfyghtr 1957 - 1960 F100 & Larger F-Series Trucks 6 12-14-2016 07:20 PM
Correcting speedo after tire size change on '95 F150 hwm3 1987 - 1996 F150 & Larger F-Series Trucks 1 07-29-2010 03:45 PM
SCT X3 and changing tire size Tim98TA Computer Chips & Tuners 7 12-13-2009 02:00 PM
05 Dually tire choice? Martini_ Brakes, Steering, Suspension, Tires, & Wheels 3 11-04-2005 08:01 PM
Tags
2011, 2012, 250, 27560r20, 67, change, duratrac, f250, factory, ford, lariat, psd, size, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
