wrench light
wrench light
FTE said the light would come on again.
the wrench light on the dash has come on again. i made it from va. to moab utah w/o seeing the light. the light has come 2 times today and the truck went into limp mode, each time i cut key off and light was gone when i turn key back on. both times the light came on when the truck was building high turbo pressure. i'm not sure what the pressure was because i was not watching at that second. i have been keeping the turbo under 26 for the trip with out a problem.
what is going on with the truck??? .
i had the truck scaned in Va. but nothing showed up. the light came on 2 times but didn't go into limp mode but yesterday the truck went into limp mode bothe times. i'm towing over 13K lbs. 5ver.
there is a ford dealer in id. i would like to use if the truck last that long. i have stopped runnning in over drive so i can prevent a sudden down shift.
thanks for your help.
thanks
thanks
Are you towing?
Definitely need the codes to know what is happening. But the most common reasons for the wrench light, that goes out after a restart, is oil cooler efficiency (oil is too hot versus coolant), over boost, or FICM voltage (weak batteries or failing FICM). My vote would be for the oil cooler. That code is a fairly recent one, and many scanners won't read it.
There are several kinds of limp modes. Usually limp mode is when vehicle stays on one gear, usually 2nd.
There are also engine default modes, what happens when a sensor malfunctions and computer puts emergency program to substitute for false reading. Depends what sensor it is, you still can have 70-90% of normal performance. Not having the scanner, you can look under the hood for cuts in hoses, or damaged wires, but that is long shoot.
Are you towing?
i 'm watching turbo psi and staying out of over drive so i can control the pressure.
hopeing to get into lewiston before any repairs has to be done.
thanks
the wrench light is related to high turbo boost because today i was watching the psi gauge and at 29 the truck went into limp mode. it feels more like the 70% t0 90% power is still there. once again i cut the key off, back on and the truck runs good.
thanks
thanks
Codes will tell the tale. Good luck.
i love my truck but this ford go to go.. engine out two times, once for a bed plate leak and once for a blown head gasket. 3 injectors replaced last year,also the air conditioner compressor and the rear brakes have been replaced.enough of my whining.
thanks thanks for all of your help. i will take this inf. with me when i go to the ford dealer in lewiston.
