wrench light - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
wrench light
Old 05-15-2012, 08:43 PM
paddler65 paddler65 is offline
paddler65 is starting off with a positive reputation.
wrench light
FTE said the light would come on again.
the wrench light on the dash has come on again. i made it from va. to moab utah w/o seeing the light. the light has come 2 times today and the truck went into limp mode, each time i cut key off and light was gone when i turn key back on. both times the light came on when the truck was building high turbo pressure. i'm not sure what the pressure was because i was not watching at that second. i have been keeping the turbo under 26 for the trip with out a problem.
what is going on with the truck??? .
Old 05-16-2012, 12:25 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
$39 OBD scanner would answer that in few seconds.
Or you can go to AAMCO for free scanning.
Old 05-16-2012, 11:18 AM
i had the truck scaned in Va. but nothing showed up. the light came on 2 times but didn't go into limp mode but yesterday the truck went into limp mode bothe times. i'm towing over 13K lbs. 5ver.
there is a ford dealer in id. i would like to use if the truck last that long. i have stopped runnning in over drive so i can prevent a sudden down shift.
thanks for your help.
thanks
Old 05-16-2012, 11:21 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Are you towing?
Definitely need the codes to know what is happening. But the most common reasons for the wrench light, that goes out after a restart, is oil cooler efficiency (oil is too hot versus coolant), over boost, or FICM voltage (weak batteries or failing FICM). My vote would be for the oil cooler. That code is a fairly recent one, and many scanners won't read it.
Old 05-16-2012, 04:52 PM
Kajtek1's Avatar
There are several kinds of limp modes. Usually limp mode is when vehicle stays on one gear, usually 2nd.
There are also engine default modes, what happens when a sensor malfunctions and computer puts emergency program to substitute for false reading. Depends what sensor it is, you still can have 70-90% of normal performance. Not having the scanner, you can look under the hood for cuts in hoses, or damaged wires, but that is long shoot.
Old 05-16-2012, 06:47 PM
Quote:
Originally Posted by bpounds View Post
Are you towing?
the wrench light is related to high turbo boost because today i was watching the psi gauge and at 29 the truck went into limp mode. it feels more like the 70% t0 90% power is still there. once again i cut the key off, back on and the truck runs good.
i 'm watching turbo psi and staying out of over drive so i can control the pressure.
hopeing to get into lewiston before any repairs has to be done.
thanks
Old 05-16-2012, 06:56 PM
bpounds's Avatar
2 bit Californian
thanks
Well, I'm surprised that it would fault at 29, but to be honest I am not sure of the limit. I know that I used to hit 29 or 30, but then with the latest flash strategy they added these engine protection items to the program, and now I only hit 27 to 28 psi. Consider also that high boost means high engine temps and therefore high oil temps. So I'm not ruling out the oil cooler problem. I hope you are right about the boost, because the turbo can be cleaned up and probably be fine with a few hours labor, but an oil cooler will be expensive to replace and you will be down for a while.
Codes will tell the tale. Good luck.
Old 05-16-2012, 08:04 PM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
Mine overbooster while towing last season. It was due to frozen VGT veins. Bismic had it nailed from the start. Although I really didn't want to believe or accept that diagnosis, he was nuts on. $650 later all was well.
Mike
Old 05-17-2012, 08:35 AM
i love my truck but this ford go to go.. engine out two times, once for a bed plate leak and once for a blown head gasket. 3 injectors replaced last year,also the air conditioner compressor and the rear brakes have been replaced.enough of my whining.
thanks thanks for all of your help. i will take this inf. with me when i go to the ford dealer in lewiston.
2011 escape wrench light and check engine light coming on smileyp Escape & Escape Hybrid 2 11-05-2016 12:44 PM
Loss of power chrisjfontenot 6.0L Power Stroke Diesel 1 08-30-2012 05:08 PM
wrench light on dash came on paddler65 6.0L Power Stroke Diesel 20 05-07-2012 05:55 PM
wrench light on my6.4Lsucks 6.4L Power Stroke Diesel 9 07-30-2011 07:06 AM
Wrench light on dash when towing turban8r 1999 to 2016 Super Duty 1 05-31-2011 01:11 PM
Tags
150, 2006, article, dash, dashboard, duty, exhaust, ford, light, magnaflow, performance, powered, super, truck, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
