[resolved] EGR problems
KOEO test. Originally brought the truck into the shop to get it checked out and they pulled codes and said the EGR valve needed to be replaced and quoted me $330.
I spent $90 and 5 minutes of my time and put a new EGR valve in myself.
After I did that it was still throwing Code 33 at me so I bought a new EVP sensor. Now I'm getting 33 AND 34 using KOEO test.
Did not measure EVP output. I have a voltmeter so I could give that a try tomorrow.
How do I go about testing the EVR? Take the EVP off and check for vacuum through the line that goes to the top of the EGR?
Thanks
Thanks
EVP = EGR Valve Position sensor. Values listed here: Fuel Injection Technical Library » EGR Valve Position sensor (EVP)
EVR info: Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
So all I did today was unplug vacuum lines, sensors, etc. and plugged them back in to ensure nothing is loose in the EGR system. Noticed that EGR valve vacuum line's rubber boot that secures the line to the top of the EGR had a crack in it. Have to track a new one down but in the meantime I just covered the crack with electrical tape. Also pulled negative battery cable to reset codes.
After all of that, now I am just getting a Code 31 doing the KOEO test. What does Code 31 mean?
I was scared too until I found another thread where they color coded the new tubing to march the ford factory colors. Just wrap each end and maybe every 8-10 inches or so with electrical tape in the same as the stock color. They wrapped to whole tube but that is too much unnecessary work for my taste. I just ordered 50 feet of vac line off Amazon for 23 bucks so I'll only be in it 30-40 and probably half a day of work by the time it is all said and done
