What do you run for fuel pressure? Edelbrock carb - Ford Truck Enthusiasts Forums
Old 05-15-2012, 05:41 PM
lannondiesel's Avatar
lannondiesel lannondiesel is offline
lannondiesel is starting off with a positive reputation.
What does everybody run for fuel pressure for an off-road truck? Is 3-4 psi sufficient?
Since my truck has been pretty dormant for a few years, I pulled the edelbrock carb off to rebuild it. I also ordered the 1465 off-road needle and seats to throw in while I have it apart. I ordered a fuel regulator also to keep the fuel pressure down. Years ago I put one on a truck because my Edelbrock had been flooding my motor with fuel after shutdown. I haven't seemed to have that problem with this one but since I am working on the fuel system, now would be the time to add it. The truck is getting all new aluminum 3/8 fuel line, a new electric pump and a carb rebuild this weekend. I think last time I used a regulator for my mud truck I was only running like 3psi of fuel pressure.
This is what I ordered, but now I am wondering if 4psi is enough:
EDL-1465 OFF-ROAD NEEDLE AND SEATS (2) 1 1Z4758400375474539
UPS: 3-4 bus. days
EDL-1477 REBUILD KIT EDELBROCK CARBS 1 1Z4758400375474539
UPS: 3-4 bus. days
HLY-12-804 FUEL PRESS REG 1-4 PSI 1 1Z4758400375474539
I forgot to get a fuel pressure gauge but I think I can get one locally by the weekend.
Old 05-15-2012, 06:07 PM
77mud's Avatar
77mud 77mud is offline
77mud has a good reputation on FTE.77mud has a good reputation on FTE.77mud has a good reputation on FTE.
I run about 8.5....
Old 05-15-2012, 08:00 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i don't have any dedicated off road rigs. everything i have is regulated to a max 6 psi.
Old 05-15-2012, 08:42 PM
I guess I'll try 4psi and see if i end up starving for fuel. This a trail rig mainly, we'll see what happens. Unless someone says that its def not enough
Old 05-15-2012, 09:07 PM
bigblockford79's Avatar
bigblockford79 bigblockford79 is offline
bigblockford79 is starting off with a positive reputation.
From the Edelbrock carb manual - "Avoid extremes in fuel pressure. At IDLE, there should not be any more than 6.0 psi; if the vehicle has
an adjustable fuel-pressure regulator, set it to 5.5 psi. With most fuel pumps the minimum fuel
pressure is encountered at high rpm and WOT. Fuel pressure should not drop below 2.0 psi. If it does,
a fuel pump with more capacity may be required."
Old 05-16-2012, 11:43 AM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
5.5-6psi as said. Which electric fuel pump did you buy?
Old 05-16-2012, 05:51 PM
77mud's Avatar
buncha weak sauce in this thread
Old 05-17-2012, 01:17 AM
Quote:
I didn't actually buy one, but I may have to, there was a blue holley in the truck when I bought it, but it didn't work. I will look into getting a rebuild kit for it. The fuel pump I am going to install is labeled Facet and doesn't have specs on it. I just did a quick search and found that it is made by purolator. It looks like the one listed here:
FACET / PUROLATOR PRO 60SV FEP 60SV FUEL PUMP | eBay
However I am not sure if it is this exact model. The case and stickers look the same but it seems they have different ratings. It was a brand new fuel pump I got for free so i decided to use it. I'll try to determine exactly which version is tomorrow to determine if it is sufficient.
Old 05-17-2012, 01:33 AM
mejonz's Avatar
mejonz mejonz is offline
mejonz is starting off with a positive reputation.
Old 05-17-2012, 07:30 PM
I use this formula to determine if a fuel pump is "enough" for a given application
HP x BSFC = lbs/hr of fuel
BSFC = .4-.5 for mild builds .6 for race .7-.8 for nitrous and boost
Fuel weighs about 6 1/4lbs per gallon.
Based off the engine specs in your sig:
400 x .5 = 200lbs/hr
200/6.25 = 32gal/hr
Id say this pump is not quite adequate and you definitely need more than 4psi. It looks like a shiney gimic part on the "cool kid rack" at your local autozone. 36gal/hr is most likely free flow capacity of the pump...not the flow under load. The Holley Red would work but IMO a Holley Blue and their adjuable regulator set at 5.5-6psi would be a better choice.
Old 05-17-2012, 09:56 PM
Thanks alpha! I will try to get my holley blue working and a different regulator! Fuel issue is moot for now, found a loose pushrod and what apears to be a smashed lifter tonight..... Guess those pushrod s were too long!
Old 05-17-2012, 10:47 PM
Since I am trying to get this all done right, I will be running new aluminum fuel line from the the fuel cell in the bed to the barb. Is 3/8" sufficient or should I get a larger diameter?
Old 05-17-2012, 10:58 PM
In a side note, I completely disassembled my carb today, I found that the far side of what I will call the "fuel rail" in the cover of the carb was packed with grit and what appeared to be white silicon. I Sure am glad I decided to pull the carb apart. The more I am seeing how much was wrong with this engine, the more I am amazed that it ran at all!
Old 05-18-2012, 12:03 AM
I have a formula for fuel line size at home but from experience 3/8 is perfectly fine.
Old 05-18-2012, 05:56 PM
77mud's Avatar
i ran 7/16's rubber line last time but now im switching to 8an (1/2) alum lines
Fuel leaking out too carburetor Marcus80 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-11-2016 04:00 PM
too much fuel pressure fix? BigCountry1978 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-08-2016 05:51 PM
Which carb is best for my engine? FatherDonald74 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 09-12-2013 12:31 AM
Edelbrock Performer Series 750CFM on 460 Bump187 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 02-08-2012 03:27 PM
Electric fuel pump cure to my problems? FordManStan 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-14-2008 01:57 PM
Tags
1411, 351w, carb, carburetor, edelbrock, edl1477, fuel, line, normal, pressure, psi, regulator, return, road, run, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
