Tow Haul
Tow Haul
After receiving so much help on my IBC issues I thought Id try one more issue.
2005 f350 6.0 4x4
having an issue with my Tow/Haul. it works fine up to 55mph, hit the tow/haul to turn it on and rpms jump around 300 or so, hit it again and it turns off and RPM's drop back down. But as soon as I get above 55mph and hit the tow/haul nothing happens, tow/haul indicator comes on but no jump in RPM's.. The RPM's are already higher than they used to be, at 65mph the rpms use to be around 1200/1400, then would jump up when the tow/haul was turn on. now at 65mph the RPM's are at all ready at 1800.
Ford says nothing is wrong, I went for a drive with the Tech, he had a computer hooked up to the truck and watched the transmission, I showed him what I was talking about and he siad "I see what you mean, but the tranny is doing exactly what it is told".
Any thoughts
2005 f350 6.0 4x4
Any thoughts
That sounds like normal behavior.
Tow/Haul mode changes the shift map. What you are seeing at 55 MPH with T/H activated sounds like the converter unlocking, or possible a downshift. Either way, the computer is telling the transmission to do this because that is what the T/H map says should happen at that RPM/Load/Throttle position. At 65 MPH, the map for T/H and normal mode agree on the gear you should be in, so nothing happens as you shift in and out of T/H mode.
One tow on my truck, towing about 9000 pounds into a stiff headwind, my truck would not shift into high gear at 55 MPH in T/H mode. Increasing my speed to 60 allowed the transmission to shift into high and allowed the RPMs to drop.
not true
I good friend I work with has the same truck, both f350 6.0's 2005 crew cabs, Same exact truck just a different color. His truck does not act this way.
at 65mph with T/H off his RPMs are down under 1400. So something has changed
12 months ago when I would be driving at 65mph, I would be pulling some where around 1250-1350 RPMs with the T/H off, now under those same condtions Im pulling 1800. something has changed.
Are the gears the same in your friend's truck?
jmo1979
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-26-2006 09:36 AM
