Preparing to do Oil Change and Fuel filters - Page 2 - Ford Truck Enthusiasts Forums
Old 05-15-2012, 06:49 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Originally Posted by GeneLaw1 View Post
Amazon.com: Lisle 14500 Oil Filter Socket: Automotive
I guess I could rock and roll with that one?
Yes, get that socket. Works for both large fuel filter and oil filter caps. Best of all, it is short and fits a 3/8" socket. Any other socket of that size would be at least a 1/2" drive which just makes it bigger and more difficult to fit in the frame rail.
I use these buckets for oil draining. I leave the whole thing at the collection place, so I don't ever have to store dirty buckets. Many different products come in similar buckets. Lately I have been using bird feed buckets instead of the cat litter. They are all 4 gallon and fit under even 2WD trucks.
Old 05-15-2012, 10:28 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
I drain into a large oil drain pan (bought at Walmart).
Then pour used oil from the drain pan (via funnel) into the empty 1 gallon Rotella-Syn oil jugs that my fresh oil came in (I at least have 3 empty ones).
If I need an extra 1 gallon jug, I either have an empty milk jug from the kitchen or an empty window-washer jug.
Old 05-16-2012, 02:06 AM
GeneLaw1 GeneLaw1 is offline
GeneLaw1 is starting off with a positive reputation.
I was in the store today and i saw a couple drain pans that are 15 qt so I will pick up one of those!
Oil drain plug and gasket ?? Long Haul 1999 to 2016 Super Duty 45 11-02-2014 01:43 AM
How to: Fuel filter and oil filter change in a 6.0L/6.4L TennesseeMustangPerf 1999 to 2016 Super Duty 28 08-17-2014 07:13 PM
Changing Fuel Filters GeneLaw1 6.0L Power Stroke Diesel 80 09-27-2012 02:49 PM
Changing Oil in Edge wedge88 Crossovers 2 02-14-2009 08:35 AM
Motorcraft Oil Filter Problems wildcard30 Oil & Lubrication 24 05-11-2004 12:30 AM
Tags
1994, attorney, cat, companies, diesal, fillter, food, ford, fuel, generals, list, office, oil, oklahoma, powered, recall, vbulletin, walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
