Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- "How to Reprogram My Key FOB?"
Guide to diagnose trouble and recommended solutions
Can't enter programming mode for new keyfob
#47
I know this is an older thread, but +1on the windshield wipers. My 2000 X wouldn't work no matter what combo of locking, unlocking, door open, door closed, etc that I tried. Then I tried the windshield wipers on and it did the trick. I simply opened the driver door, unlocked the rest with the button, left the door open, turned the windshield wipers to the first setting, cycled ignition 8x and it went right into programming mode, allowing me to program both my new remote and my old one. Hope that helps someone!
#48
I have this same issue.....I program the fobs, they work for a month and then stop.....reprogram.....works for a month then stops.
Any ideas on how to fix this? 2000 Ex, 7.3l.
Swmpbgy1
#49
Unable to program old or new fobs after entering program mode
I have a 2000 x V10 with only 121,000 miles. Both key fobs quit working years ago so I tried to reprogram them with everyone's suggestions. Nothing worked. I purchased a new one and it won't work either. After the 8 times, the doors will lock and unlock but nothing happens when I press any button on the fobs. All power locks work and so does the door keyless pad. The only improvement I did was upgrade my stereo system to a touch screen and added a backup camera. Any suggestions would greatly be appreciated.
#50
#51
The original fobs weren't working after I bought it back from my son. He did have a fancy system put in that played movies. Since I didn't want that he put the original system back in. I guess he could have disconnected/cut/moved something. What would one look for when the stereo is removed? I'm thinking that could very well be the issue.
#52
#56
Not enetering programming!
Hey Guys,
I did a search here and on Google and didn't see anything with the exact symptom that I'm having.
I have a new keyfob for my wife's 2000 X, and I'm trying to program it. The procedure is simple, right? Get in the truck, put the key in the ignition, lock the doors, unlock the doors, then cycle it to the run position (back of off), 8 times -- staying in "run" the eighth time.
I've done this OVER and OVER after my wife said it wouldn't work for her. The problem is that when you hit run the 8th time, the locks should cycle, indicating that it is ready to program the remote. The problem is the locks never cycle.
I also tried the same procedure without the locking and unlocking step prior to turning the key. And I also tried it by locking and unlocking prior to inserting the key.
Seems simple, any idea why it won't work? I can't find ANYthing regarding other people with this problem.
TIA!
Patriot_RAM
TIA!
Patriot_RAM
My F350 is not enetering programming mode, just bought it only has 40,000 miles and no fob came with it. Bought a fob off of rock auto and went to program it and my truck does not enter programming mode. I’ve done the 8 key turns constantly but a last nothing has worked.
#57
#59
