300 date code, engine date code - Page 2 - Ford Truck Enthusiasts Forums
Old 05-23-2012, 03:39 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Originally Posted by fordman75 View Post
It's E7TE, not BTTE.
Correct.
Even still, it's a Casting ID and not a date code, the actual date the block was cast is located elsewhere.
Old 05-23-2012, 03:47 PM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Quote:
Originally Posted by ctubutis View Post
Correct.
I know that!
Old 05-23-2012, 05:12 PM
jem44357's Avatar
jem44357 jem44357 is offline
jem44357 is starting off with a positive reputation.
The # at the front of my head is 8 D 1 4. This make my head cast in '78 in the month of April on the 14th day?
Old 05-23-2012, 05:34 PM
ctubutis's Avatar
Quote:
Originally Posted by jem44357 View Post
The # at the front of my head is 8D14. This make my head cast in '78 in the month of April on the 14th day?
I am assuming you tried to say 8D14.
At the bottom of the Advanced Editor window are 4 checkboxes; check the box that says:
Disable smilies in text
That will keep the "8D" from being interpreted as a smiley-face.
Yes, April 14th, 1978 is the casting date of that head if the Casting ID Prefix begins with a "D".
Old 05-23-2012, 05:54 PM
jem44357's Avatar
ctubutis,
Thanks for all of your help. I was starting dinner when I posted. I just returned and clicked edit and added spaces before I saw your post.
Thanks again
Jim
Old 05-23-2012, 06:25 PM
ctubutis's Avatar
ctubutis,
Thanks again
Jim
No prob, hope it helps.
BTW I want to explain something I already explained to Justin (AB) that some of you guys may be raising one eyebrow in a Spock-lie fashion at....
Specifically, look at the information given for 1980/83 engine blocks:
Notice it says for MY 1980 through 1983, use a replacement engine block with an E7 prefix.
This means that, during the 1980-86/7 time period, the block used for 1980/83 engines either 1) Went through revisions, or 2) Was combined with a block used in later years.
In either case, Ford eventually came up with one replacement block to use for all of 1980-86 engines (yes, I see that E4 1984/85 thing, but notice how it's obsolete and and was replaced, I would guess by the same E7TZ that all the others use but I don't know how to look up that "mat # 85051" code to verify that).
It looks to me like they eventually came up with one block to use for carb'd engines, and one for EFI.
Point being, Ford didn't design a 1980 block and give it a Casting ID with a date in the future.
BTW my M-block, in addition to the Casting ID and Casting Date codes, IIRC it has an Engine Assembly date stamped elsewhere into the thing, I think right by the timing case cover.
This is wholly separate from the other codes.
I would have to assume the 6-banger also has that somewhere but I wouldn't know where.
-chris
Old 08-27-2014, 06:47 PM
twin me beam twin me beam is offline
twin me beam is starting off with a positive reputation.
Hi, New member here. Not sure I'm posting this in the correct location. I have a bitza 1964/1965/ pickup. (bits of this and that from here & there). It has two different vins that I'm working out with the California Highway Patrol. The reg & title belong to a 1964 drivers side door warranty plate but nothing else on this truck..
I Finally figured it's a 1965 twin I beam from the chassis vin.
When new it had a 240, "J" engine code.
I Measured the stroke down the rabbit hole and found it to be a 300 (almost 4" stroke).
The numbers forward of the starter are "D1AE-8015-CA OK fomoco"
The 8015 may be a 6015. My 72yr old eyes are fading.
After reading these thread notes it appears to have been cast Oct 1970 .
But the A instead of a T means it was not a truck 300??????????
The block and head are painted red and it looks to be original paint.
The pan is ford blue. Valve covers black.
Beneath the passenger side motor mount is a very large C with a capital F inside the C. There are other marking there but I can't make them out.
Many of the intake manifold tabs are broken off.
I'm surprised it doesn't suck air.
It idles fairly well/165psi compression each hole.
Any thoughts regarding identification of this engine?
Thanks in advance for any help.
Russ,
400M Casting Codes and Date Stamps fyreduck1921 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-02-2013 02:41 PM
need vin and axle decipher on f800 mrblonde108 Large Truck 2 02-06-2011 03:11 PM
Block date code gfw1985 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 11-19-2008 06:06 PM
Need Help with 400 block date code 78longbed 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 12 05-23-2007 08:14 PM
460 date codes toddn78 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 12-30-2004 02:25 AM
Tags
300, 49, aa, block, casting, code, codes, coding, date, diesel, engine, enn6015, ford, marking, mirror, motor, ph
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
