Need a relay
Need a relay
My truck trailer connection has no power to the + pin, called the Trailer Tow Battery Charge. I traced back to the fuses and relays and discovered the relay missing. Unbelievably Ford is having a hard time with this relay. They don't seem to be sure which one it is. My owner's manual says it is a Full ISO relay. But Ford doesn't like that description.
What can I use there? Is there any after market relay available that would fit. Napa said they don't have anything listed, and O'Reilly and Autozone look at me with a stupid expression. I also need one for the starter relay. Mine was replaced with a anti theft device that has a remote control. I want that removed so I need the realy. All the relays appear to be the same. I plugged in the blower motor relay in the trailer tow charge position and got power to the + pin. But I need the blower motor. The Ford guy said that it might be the right one, but he couldn't be certain and if I plug it in and it doesn't work it's my loss. At $27 to $34 each I want to be sure.
Maybe the parts guru can tell me what's possible.
BTW - This is for the 2006 F-150, 4.6l truck.
Thanks all.
Thanks all.
Last edited by ScottInTexas; 01-14-2009 at 12:02 PM. Reason: Clarify which vehicle
F0AB 14B192-AA is the correct Ford part number for this relay (for my 1997 F150 4x4).
http://www.fordpartsgiant.com/partli...7-1923401.html
cpye2
1999 to 2016 Super Duty
12-27-2013 01:16 PM
LeeTribeRide
11-09-2013 04:10 PM
The Masked Rider
10-11-2013 04:30 PM
