My 54 F100 project - Page 4 - Ford Truck Enthusiasts Forums
My 54 F100 project
  #46
Old 02-16-2014, 11:09 PM
Rhinoh22 Rhinoh22 is offline
Rhinoh22 is gaining momentum as a positive member of FTE.Rhinoh22 is gaining momentum as a positive member of FTE.
Been a while since any updates, life caught up with me. Looking to start on small easy jobs, the top of the bed sides have been dinged/bent, is there an easy method to reforming the approx 1" holes that run the length of the bed? I would like to keep as much of the panels as possible as it has all original sheet metal, but the tailgate suffered a bit too as it was a work truck for many decades. Any ideas or links would be awesome
I'm also considering the Crown Vic front end swap as opposed the the Toyota steering box swap, and maybe just going for the whole 4.6L/trans from similar car. Has anyone done this swap or have any suggestions? I'm not looking for it to be a hot rod, just reliable driver.
  #47
Old 07-19-2014, 08:15 PM
Well a small update, got the truck up on jack stands, ripped the entire brake system apart and rebuilt/replaced everything. Just need to clean up the drums, repack the front bearings and bleed system.
Next up while its still in the air is removing the gas tank and cleaning out any sludge in there as the truck has been parked since 1980.
  #48
Old 07-20-2014, 02:29 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
You should look to Northern Classic Trucks for a new tailgate....they are in Sterling Heights, Michigan. He makes a very nice scripted version.
  #49
Old 07-20-2014, 05:12 PM
Well update for today isn't as good as yesterday, got the tank out, which wasn't fun in itself, and the whole top is rusted out, so no clean and reinstall for me, gonna have to scrape some bucks for a new tank. Oh well.
Thanks Dan, I'll check em out.
  #50
Old 08-28-2014, 09:42 PM
Ok, time, money, and motivation are finally falling in line with each other. I have ordered a new tank, old one was worthless due to rust, as well as sending unit. TRuck was a 6v, rewiring truck and going 12v, question is: What sending unit do you guys recommend? It has a 292 Y-block currently, but will be upgrading later. Tank I bought says it accepts stock 6 bolt and aftermarket 5 bolt senders.
Very excited, once tank goes in, should be able to attempt to start the truck for first time in 34 years!
  #51
Old 08-28-2014, 11:35 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
You will need to decide what fuel gauge you are going to use, as that will determine what sending unit is needed. Mid fifties should have what you need if using a factory gauge. I used a SW gauge, and got the sender from Speedway.
  #52
Old 08-28-2014, 11:39 PM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
Yup, sometimes one step forward and 2 back. But keep up the quest. It took me over 10 years to get my '54 running but believe me it's worth it.
  #53
Old 08-29-2014, 04:17 AM
Bluey Zedoff's Avatar
Bluey Zedoff Bluey Zedoff is offline
Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.
Quote:
Dan, I tip my hat to guys like you. Ten years is a while, and I really draw inspiration from guys like yourself who never give in.
  #54
Old 08-29-2014, 12:31 PM
Old tank is shot, I ordered a brand new one.
  #55
Old 08-29-2014, 10:10 PM
Hotwire Hotwire is offline
Hotwire is starting off with a positive reputation.
Rhinoh22,
You are a couple of years ahead of me in my rebuild of an identical '54 F100, same 239 motor and appears to be same original color, Glacier Blue. At least my interior is still original, the exterior was painted black.
We have some of the same issues, including the heater, which looks similar on the interior. The wiring and heater hoses look the same on the engine side of the firewall.
I had the original 16 X 4.5 rims broken down. Then I cleaned the rust off the interior and primed them. Now that I have all 5 tires holding air, I want to start with the wiring.
Which harness did you use?
Thanks for the great thread on your project. It has been a big help already.
Hotwire
  #56
Old 08-30-2014, 08:07 PM
Hotwire,
As of now I have a universal kit from ebay, forget how many circuits, but came with fuse block and lots of wire, havent got it fully installed yet to see how it works.
  #57
Old 05-02-2015, 05:57 PM
So, been a while since last update. Got motor wired up, new fuel pump, coil, solenoid, fuel tank installed. Fired on first try! Idles ok but need more tuning of course, been sitting so long.
But couldn't run long, radiator is fried, leaking everywhere and have no pulley on water pump. The snout seems bigger then the pullies I have around, its a 1960 292 and none of my fan pulleys fit over it?
  #58
Old 06-04-2016, 12:48 AM
Well its been a long time since last post. I've got the 54 on the road, so to speak, gone through DMV hoops to get it on the books again and titled in my name.
  #59
Old 06-04-2016, 12:51 AM
Added a 1 wire alt and got charging system going, fabbed brackets from original generator mounts, but need a little more work
  #60
Old 06-04-2016, 12:53 AM
Using an American Autowire kit, I rewired the truck from front to back, all systems are newly wired and working great
Need an '11-'16 lower cup holder panel edman1000 1999 to 2016 Super Duty 10 10-03-2016 10:12 AM
2002 Ford Excursion 7.3 powerstroke volthause Vehicles for Sale 1 06-11-2015 01:52 PM
Worn down camshafts n cylinder heads Bryangoku 1999 to 2016 Super Duty 4 01-12-2015 12:29 PM
igniton switch actuator reference photos xkpsanit 1987 - 1996 F150 & Larger F-Series Trucks 1 09-26-2014 09:45 PM
dads old 79 rebuild customrich&matt 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-01-2012 07:47 AM
Tags
100, 1970, 49, 50s, 54, chassis, delaware, diagram, end, f100, front, fuse, grafting, mustang, rewiring, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
