Titan 50 Gal Fuel Tank - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 02-10-2013, 07:45 PM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
You are most welcome...and welcome to FTE.
  #62
Old 02-22-2013, 05:16 PM
AggieFord's Avatar
AggieFord AggieFord is offline
AggieFord is starting off with a positive reputation.
I foresee this mod in my future. I purchased a used 2011 with the idea to tow the travel trailer (RV) all over the South. Well, I was a little disappointed to learn it only had a 26gal tank. I see a LOT of fuel stops in my future, but 50gals would be nice......
  #63
Old 03-21-2015, 04:42 PM
His Grace His Grace is offline
His Grace is starting off with a positive reputation.
Quote:
Originally Posted by Tuxedo Scorpion View Post
Definitely has me intrigued. But only if i knew for sure i could get the MTE to be calibrated for that size as well as having an accurate fuel guage. Install seems easy enough
March 17th 2015, I had my 50 gallon titan tank installed. 3 fill ups so far and it's been amazing. Love not having to pull into a gas station every 200 mikes pulling my 40 ft silverback 37bh. The dealership installed it at Ford, so it is covered under warranty. I do hear sloshing a tad bit when I get to about half a tank but not bad at all. I did notice that after hearing the sloshing, I looked under neath and when the tank is almost empty, ypu are able to move the nose of the titan tank about half an inch back in forth because the third strap (not really a strap because it is only connected to the frame one on the drivers side) which is really just a limited support brace because the majority of the weight is carried by the two mid body straps. That kinda had me concerned but I believe that maybe normal play. The dealership also flashed the pcm to read the larger tank. Now I get 750 miles to empty! One thing I noticed today was that I had 85 miles left on the fuel gauge and when I went to fill up I could only get 39 gallons in. So I am suspecting that when you get to the empty gauge you have roughly another 5 gallons left?! Has anyone else experienced this?. I also had the firestone ride rite air bags installed and the BMW fifth wheel and companion. My 2012 F250 pulls this massive trailer with no problem.
  #64
Old 03-21-2015, 05:01 PM
Just Strokin Just Strokin is online now
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Quote:
Like you, it was nice to go more than 200-300 miles before fueling. Mine being LWB and a 65 gal Titan tank, I have gone as far as 600 miles pulling my 5'r to Denver last year. It was nice to be able to be selective on where I bought fuel and the price per gallon. And not pulling, it is nice to see over 950 miles to empty to show.
I noticed when I ran my stock tank "dry" to install the Titan, It showed 0 miles to empty and when it was removed, there was over 3 gallon left in it.
I do not watch the gallons to empty so much when on a trip but the trip meter. I reset Trip A at each fill up and then watch it to see how many gallons are left to anticipate my next fuel stop.
  #65
Old 03-21-2015, 05:30 PM
Thank you Just Strokin, I appreciate the info on the empty tank still having three gallons in it. For a second there I thought maybe the Ford installers put a 40 galloon tank in or something. And to anyone reading this thread, realize your contribution and knowledge is helpful. After reading this thread, I bought my titan tank and with everyone's collaborative knowledge it helped me to make a good decision. So if you have info, post, this is a brotherhood and our posts help each other out.
  #66
Old 03-21-2015, 05:32 PM
Rich53 Rich53 is offline
Rich53 is starting off with a positive reputation.
I put the 50 gallon titan tank in mine, found the same behavior in terms of distance to empty, but it did the same with the stock tank. I found that if I ran the stock tank down to almost 0 on the miles to empty, I could only put about 21 gallons in it, with the titan tank I can put 45 gallons in it. So the new tank more than doubles my usable range, and it was great towing my 10K boat and trailer, could do almost 400 miles between fills, instead of 180-200, depending on how daring I wanted to be. On my trip to Florida that i do every year it saved me almost 2 hours of fueling time, since I always have to go to the truck stops and either use the pumps out back or the RV islands, and the crowd doesn't move fast in either location. So it made a big difference.
  #67
Old 03-21-2015, 05:41 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I added a 60 gal toolbox tank to the bed, so I have 98 gallons on board..
I can go almost a 1000miles towing.
  #68
Old 03-21-2015, 06:17 PM
I almost went with a bed fuel tank, but I didn't want to deal with having to get out of the truck and switching the know and waiting for it to fill up the native tank. Plus I wanted to keep my standard bed f250 free of apparatus so I wouldn't give any room up for the fifth wheel. I choose not to go with the slider being that the Cedar Creek Silverback 37bh had grooves in the head cab enabling me to turn a little sharper. Plus, I liked the stock look of the titan.
  #69
Old 03-21-2015, 09:03 PM
sdetweil's Avatar
Understood. Not a lot of room to give up on the shortbed trucks.
One minor thing, if both tanks need filling, I fill the stock tank first, then the aux tank. No waiting.
  #70
Old 03-21-2015, 09:27 PM
I fully understand.
  #71
Old 03-23-2015, 08:34 AM
U235Fishin' U235Fishin' is offline
U235Fishin' has a good reputation on FTE.U235Fishin' has a good reputation on FTE.
I installed the Titan 50 gallon tank about a year ago. Love it! As far as operating the truck, when down to the last eighth of a tank, I also monitor the fuel used on TRIP A that I reset every fill up. I have found that it matches the fuel added on the fill up to about a gallon or so. Also since the Titan tank is relatively long, for and aft, as compared to the stock tank, the orientation of the truck will change the DTE display and maybe the low fuel alarm if the level is close to that point. Also realize that the fuel suction and the level sensor is located aft in the tank. So, being a little paranoid, when I am going to drive some steep grades, I like to have a quarter tank or more so when I nose the truck down and the fuel moves forward in the tank away from the suction so I won't have a problem.
  #72
Old 04-21-2015, 12:15 PM
wallmon's Avatar
wallmon wallmon is offline
wallmon is starting off with a positive reputation.
Just had a 50 gal Titan tank installed in my New F250 SD by the local Ford dealer. The install and calibration took 2-3 hrs with no problems. Anybody want a OEM 26 gal tank and skid plate?
  #73
Old 04-21-2015, 03:24 PM
LabCab LabCab is offline
LabCab is a splendid one to beholdLabCab is a splendid one to beholdLabCab is a splendid one to beholdLabCab is a splendid one to beholdLabCab is a splendid one to beholdLabCab is a splendid one to beholdLabCab is a splendid one to behold
Wallmon,
Congrats, what did your Ford Dealer charge for the whole thing?
I would love to jump to 65 gallons, though the 37 gallon tank has not been an issue to me so far like the 26 gallon tank always was....
Pat
  #74
Old 04-21-2015, 03:37 PM
wallmon's Avatar
$350 Saved me from dropping a bunch of "F" Bombs and mashed knuckles. Thought it was fair. 3 hrs labor
I think if my F250 had come with a 37 gal tank, I might not have messed with the 50 Gal Titan. But, 26 gal really wasn't acceptable. It's Really a nice solid tank that looks every bit as good as the OED tank if not better. I'm very happy with my whole experience.
The dealership has installed a number of these tanks and was at least in my opinion almost endorsing the extra tankage. They like the tank!!
  #75
Old 04-21-2015, 06:55 PM
I would do it for that in a heartbeat as they should also guarantee their work.
I will have to check with my dealer if I ever decide to do this modification.
Enjoy your extended range, I am still not sure why Ford doesn't have a larger tank as an option for the Super duties..... One would think that it would be extra profit as most would be ordered that way. Heck they are starting to do it for the 2015 F150s....
Maybe in 2017....
Do any of you guys use gas cards to feed your 460s? DieselCamper 1973 - 1979 F-100 & Larger F-Series Trucks 13 11-09-2016 05:49 PM
Titan Tank Question erik512 6.7L Power Stroke Diesel 17 08-06-2016 10:20 AM
F250 6.7 dsl Titan 50 gal tank Greynomad 1999 to 2016 Super Duty 1 12-28-2015 10:41 PM
2015 F250 OEM 26 gal Diesel Fuel Tank cavementech 6.7L Power Stroke Diesel 4 08-19-2015 09:38 AM
Has anyone used autoplicity.com? buckmasters 6.7L Power Stroke Diesel 12 02-11-2015 01:53 PM
Tags
50, diesel, excursion, f350, ford, forums, fuel, gal, gallon, pump, sb, tank, tanks, titan, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
