1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Can Torqueshift thermostat be removed?
Old 05-14-2012, 10:27 AM
Saxon's Avatar
Saxon
Saxon is offline
For the process of thouroghly draining the trans fluid, can the thermostat in the transmission be removed? And then reinstalled afterward.
Old 05-14-2012, 10:39 AM
maverick22's Avatar
maverick22
maverick22 is offline
I have no idea but even if it could it's likely not easy to get to. Is all that work really worth the extra $100 it costs to have the dealer do it on a heated flush machine?
Old 05-14-2012, 03:32 PM
Saxon's Avatar
Saxon
Saxon is offline
Thats the reason for asking, to weigh it out.
Please, technical respones.
Old 05-14-2012, 06:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,571 Likes on 1,049 Posts
Anything can be removed, so can the thermostat.
Remove the transmission from the truck. Remove the torque converter. Unbolt the pump. Use two of the bolts in the two threaded holes with a slide hammer to pull the pump out. Now disassemble the pump to get to the thermostat.
So I guess the real answer is no, you can't remove it.
Old 05-14-2012, 08:03 PM
Saxon's Avatar
Saxon
Saxon is offline
OK Thanks. Now that is technical instead of opinionated.
Yes, anything assembled can be disassembled. No doubt in this case it is not worth it.
Old 05-14-2012, 09:34 PM
whalerron's Avatar
whalerron
whalerron is offline
$100????? Really????? I just had this job done here in Maryland and the Ford dealer charged me $240 for the flush and fill. They added on another $50 or so for the external filter.
Old 05-14-2012, 10:52 PM
maverick22's Avatar
maverick22
Yes really. If you read my post I said an EXTRA $100. I was quoted $250 w/ the filter, so that was my starting point. Have you priced Mercon LV lately? Here's a link to it at O'Reilly's: Motorcraft MERCON LV - Transmission Fluid | O'Reilly Auto Parts so 17.5qts at $4.79/qt, that's $84. According to Ford Parts Buy 2005 Ford F-250 Super Duty Parts | FordParts.com my filter for a pre March 2005 build is $64, for a grand total of $148.
Old 05-15-2012, 07:08 AM
whalerron's Avatar
whalerron
Whew! I thought I was really shafted by the dealer. I missed the word "extra" in your post. I am still a bit perturbed that the cost of their inline filter was over twice what I could get that same Motorcraft part for elsewhere.
hakukamana
03-26-2013 12:39 PM
gunnarGSD
01-21-2011 10:11 AM
whalerron
11-15-2007 07:09 AM
pfeifer5
1997 - 2003 F150
11-20-2005 12:49 PM
Spktyr
06-06-2004 05:17 PM
Quick Reply: Can Torqueshift thermostat be removed?
