slightly o/t; car trailer winches - Ford Truck Enthusiasts Forums
Old 05-14-2012, 09:55 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Over the weekend I picked up a good used 20' car trailer. I always thought a winch would be a good thing to have. Just wondering if anyone here has any experience on what a good winch size, brand, type, etc., would be? Anything in particular one should stay away from? Any words of wisdom passed along would be appreciated.
Old 05-14-2012, 11:54 AM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
I just bought a warn 3700 pound Warn winch at lowes on clearance. I was a little leary to buy this because of the low weight pulling power rating but I gave it a shot. The winch works great!!! I have never had a problem pulling a truck onto my trailer.
You definately want power in/ power out so the winch will work in reverse too. My previous winch only had power in and you had to come a long the car off because it just free spools in reverse. Stay away from that, its dangerous and very time consuming.
If you get something around 4,000 pounds, power in/ out and a cable length of 40 or 50 feet I think you will be pleasantly suprised.
Old 05-14-2012, 01:19 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
I use a winch to get my green truck on/off my enclosed car hauler, cause you can't open the door..
initially I used a small 3500lb winch.. with wireless remote control, not wired.
I wore out 3 of these in a year..
then I found a 10,000lb, 3/8in 100 ft cable, wireless.
I got it from Ebay, $350 I think like this one.
NEW 10000 LB 10000LB WIRELESS WATERPROOF RECOVERY WINCH | eBay
and it works great..
Sam
Old 05-14-2012, 01:20 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I have a 4000 lb single pull marine type power winch brand that I use on my trailer. If needed, I use it with the block which doubles the pulling power I've had it for many years. It was not my first choice but it was something I had. It is not power out but so far I've not really needed power out although it would have been nice a few time. I've loaded cars, Jeeps, tractors, trucks, ATVs, loaded personal water craft trailers, truck bodies, and even dragged parts onto the trailer.
I've overloaded (abused) it and had to make an adjustment but all in all it has served me well. It would not be my first choice if I were going to buy something.
I have an 8,000 lb Warn that I took off my Jeep that has worked flawlessly.
Keep in mind when sizing the winch that rolling power is a whole lot less than dead weight. Also be mindful that pulling a vehicle with flat tires is just about like pulling dead weight.
Old 05-14-2012, 01:34 PM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
I like my Ramsey REP8000. I've had it now for about 10 years. I've also had a Warn 8000 pound winch befor I got this one... weve mounted a few on trailers and have done it a few ways, I like to use a receiver type so the winch isn't always mounted on the trailer. It can be removed and locked up. The plug-in allows you to use it to recharge the battery on the trailer when your not hooked up to a tow rig.
Old 05-14-2012, 02:28 PM
sdetweil's Avatar
Quote:
I also use a platform and receiver hitch, mounted to the trailer floor.
I have an Atwood power trailer jack, and keep the battery charged with a small 10w solar panel and controller. The battery drives the jack and the winch.. the power cables on the winch use connectors so I can move it to the truck if need be and use its power instead..
found the jack on craigslist, for $100.. best deal ever
Sam
Old 05-14-2012, 08:59 PM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
[QUOTE=sdetweil;11831191]I use a winch to get my green truck on/off my enclosed car hauler, cause you can't open the door..
Hey Sam,
If you drove it, you wouldn't need a winch! LOL
Old 05-14-2012, 10:26 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Got a 7000# Mile Marker winch. I'm sure it's a china brand of some sort. However, it's been taking the abuse we throw at it. All the garbage dad and i have drug up the trailer since it was installed in 2004 and it still keeps on going. So far it has pulled at it's heaviest a dent-side SCab with 460 and half flat tires. As long as the battery is fresh, it seems to move right along. It's what we used to load up my '56 when it was dead weight and having an addidional 460/C6 in the bed if it aswell..
Old 05-14-2012, 10:50 PM
sdetweil's Avatar
Quote:
Hey Sam,
Really funny!!
Sam
Old 05-14-2012, 10:54 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Buy the biggest winch you can! speaking of winches, is it a winch or a wench? As you can see i call them winches; not wenches..... isnt the wench someone you bring along (only if your from south dakota). to operate the winch while you steer! . no offense to anyonyone from SD. im speaking for myself i guess. I just see a lot of ads where people call them wenches.... just my pet peave i guess.....
anyway, i found a killer deal on an older Warn 8000 ? it does not free spool but powers in and out just fine after i replaced a couple of the solenoids. i have pulled F6s and a 56 c600 with 2 flat tires up on my trailer with it. i think it needs another solenoid replaced after that one though.
i had my 6 yr old running the controller while loading a 52 f6 without a flatbed and it was still.in gear and he had it half way up the trailer before he finally stopped so i could put it in neutral..
also can use some ****** blocks to double your pull if need be.
winches are great, i pulled a n olds engine a couple hundred feet from and old shed slifing it on a large sheet of plywood zigzaging between trees till it was close enoigh to load
edit: I can spell, i just have been doing without my home computer since december so im typing on my dumb phone. although ive heard them.called smart phones im not so sure...
Old 05-14-2012, 11:08 PM
52 Merc's Avatar
Quote:
I'm with ya there. Nothing will get me started like some moron telling us he has a "worn wench" for sale. Sounds more like a personal problem...
Thanks for the comments, guys! I was looking around the area craigslist ads yesterday and found a few old Warn's and a Ramsey or two. I know those are good quality units, but the money people are asking for for some of those that look pretty used up is kind of sticker shock territory. I saw on the etrailers website they have a Superwinch brand that was a 5K winch for about $400, and there was a 4x4 outfit that had a similar sized Smittybuilt for $300. Or like I said, I can double that and get someone's old, used name brand winch and hope it still has some life left. For some reason, though, I seem to recall reading somewhere that one or both of those brands weren't worth taking home. (But I could be mistaken) I figured there's got to be someone here with some knowledge on the subject, so keep the comments coming.
Old 05-14-2012, 11:25 PM
jmadsen's Avatar
Cant go wrong with one of these, batteries not included.
KSL.com Mobile
here is a wench!
KSL.com Mobile
And yet another Wench!!!
KSL.com Mobile
although im sure you get what you pay for with that one.
the other reason i think ive got at least another bad solenoid now is that the winch has to ne hooked up to he truck battery and engine running to pull anything.
Old 05-14-2012, 11:41 PM
52 Merc's Avatar
KSL.com Mobile
here is a wench!
KSL.com Mobile
KSL.com Mobile
The first one looks like something my Dad would've used. We had a push reel lawnmower for years when I was a kid, until my Grandpa took pity on us and gave us his hand-me-down gas mower when he bought a new one.
Old 05-16-2012, 11:37 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I agree with others that stated to get the biggest size winch you can get. About two years after buying my trailer I got tired of loading vehicles on it with a come along and pushing.
With the help of my wife (she bought everything), we purchased an aluminum Delta box from JC Whitney, an Optima deep cycle/marine (blue top) battery from Costco, and an 8000 lbs winch with wired remote from Harbor Freight. I don't remember if the channel winch mount came with my winch or if I purchased it separately, but it's a good base to have for mounting. At that time, the whole set up cost about $800 or $850.
I wanted a box in order to protect the battery and the winch from the outside elements. I bought the largest box in order to have room for the winch, battery and also to have plenty of storage for my tie-downs, wood blocks, emergency triangles, small tools, safety cones, etc. Since I tow with two different vehicles, I wanted the trailer to be outfitted with an onboard battery so I wouldn't have to mess with different cables and having to wire both vehicles. Instead, I just have matching 7-pin connectors on the trailer and the two vehicles.
I built a base out of rectangular steel tubing to raise the box and level it with the deck. I also put a layer of 1/4" steel on top of the structure and bolted the box and winch through the metal base. The base is butted up directly against the trailer to prevent any cracking of the trailer tongue and to add support/rigidity. Granted this adds a bit more weight on the tongue, but I center my loads to compensate for the slight increase in the tongue weight.
I've had this set up for at least seven years now and have towed about a dozen parts trucks, as well as my own and my friends's vehicles more than a handful times. The battery is hooked up to the 7-pin connector and is charged when I tow the trailer. I have never kept a battery charger on the battery. The winch has also performed well throughout the years. I knew that the quality of a HF winch isn't as good as Warn or another name brand, but I took my chances, and am pleased that I did. HF now has a 12k lbs winch and I'm thinking about replacing mine just for the heck of it. They no longer sell the 8k winch that I have, but do have a 6k, 9k and 12k models. Just to let you know, my current 8k lbs winch had no problem pulling a 52 F6 with a 16' flatbed on the back onto my trailer. Towing it with my trailer and tow vehicle was another story.
BTW, the box is also a great stopping tool in case you forget to tie down the vehicle and start moving. Don't ask me how I know, but thankfully the box was able to stop my Airflow. The aluminum structure of the storage box is also easy to straighten.
Delta aluminum trailer tongue box - Delta Aluminum Trailer Tongue Boxes - JCWhitney
Optima blue top battery - Amazon.com: Optima 8006-006-FFP BlueTop Group 34 Marine Battery: Automotive
HF winches - Winch - Harbor Freight Tools
Old 05-17-2012, 12:41 AM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
I've got a 20 foot car trailer. I've got a 12,000 pound Mile Marker winch. It's not a Warn or Ramsey but it works.
I've loaded a lot of vehicles with it. And many of them with flat tires or locked up brakes. And not all small vehicles either. Lot's of 3/4 and 1 ton trucks. Even a couple heavier grain trucks. I've been using and abusing it for well over 6 years now. Sure beats hand winching them on with a come-a-long!! That's the way I loaded them for a few years before I bought the electric winch.
Bed mounted winch RedZerOne Aftermarket Products 16 02-14-2016 10:25 AM
Winch for F-350 SMLWinds 1999 to 2016 Super Duty 38 01-06-2016 07:57 PM
92 - 97 winch bumper. nolan94f350 1987 - 1996 F150 & Larger F-Series Trucks 2 10-12-2015 10:05 PM
How do I install a winch, beginner help Farmer Doug 1999 to 2016 Super Duty 5 06-04-2015 07:51 AM
Car Hauler Winch Battery gfw1985 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 09-10-2014 12:57 PM
Tags
3500lb, battery, car, cordless, f150, forum, good, jack, marine, power, powering, remote, reverse, seperate, trailer, truck, winch, wireless
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
