Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-13-2012, 11:26 PM
ajsanteiro ajsanteiro is offline
Garage is empty, add now
ajsanteiro is starting off with a positive reputation.
Post CAT 3208 Injector Pump Seals & set-up guidance
Here we go! First post to this information MECA.
I'm in the research stages of converting a non-turbo Caterpillar 3208, to run on SVO. Or rather, filtered and de-watered WVO. (They use to run these in the 7000 and 8000 model Ford's back in the 80's)
I mainly I come to you today in search of the option of rebuilding the 3208's fuel injector pump with viton seals, capable of handling the exposure to the vegetable oils without breaking down like regular rubber. Any experience in rebuilding these injector pumps? Think the viton seals are even necessary?
FEEL FREE TO CRITIQUE, PLEASE!
This is my parts list / set-up so far,
In order from tank to combustion...
Tank - aluminum - 50gal
bought on craigslist
$60
Coolant Heated fuel pick up w/ no reactive metals.
Arctic fox? DIY?
$50-$200
- or
Heated Tank Pick Up
Vegmatics Online Shop
$192.50 - $200.00
Aluminum/SS braided fuel line ( from fuel tank - to cheap 1st filter - to fuel pump - then to the 2nd, coolant heated filter ) *wvo approved viton inners.
$50?
Basic spin on - cheaper - replaceable - fuel filter w/ viton seals (to have a cheaper filter to change more often…)
$100?
Fuel Pump Raptor100 or WVOdesigns pump for $445!?
$350-$445
Coolant Heated Fuel Filter - Racor 360RC - 2, 10, or 30 micron
$334.00
http://www.snapgreentech.com/product...category_id=44
Racor R90S - Replacement filter for Racor 360RC
$28.83
Racor R90S ELEMENT ASSY-490R, 2 MICRON
HIH ( from heated filter to solenoid switch. )
$100?
3 way solenoid valve switch - (2 of them) for looping fuels back to individual tanks
$100?
Aluminum/SS braided fuel line (branched off the HIH fuel line that is coming from the coolant heated filter, for the reason of looping the fuel back to the tank for circulation/purge) *.*.*NEEDS MORE RESEARCH! *.*.*
$75?
HIH ( from switch to FPHE )
$75?
Flat Plate Heat Exchanger - minimum 26 plate - preferably nickel brazed - for final heating before Injector Pump
$100-$350
Fuel Pressure, Temperature Guages & In-Cab/Dash switches
$200?
Fuel sender w/ if possible, one proven to work with WVO…
$50?
btw... you can see PICTURES of the vehicle HERE--> www.brokencompassproject.com
  #2 (permalink)
Old 05-16-2012, 02:34 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.
ranger_nog hairyboxnoogle
Dont know anything about WVO but i think the pump should be fine with it given there is no water. Diesel will eat regular rubber so i would think it probably has the viton stuff in it.. just a guess.
__________________
'92 F-250 XLT, Dads - Supercab, 4x4, ZF, 7.3 ATS 088. Mostly stock for the moment.
'79 F-350 Custom, Disassembled-Super Cab Flareside - Getting 250cc 4k-kit P-pump, compounds, and 9spd
Tags
3208, arctic, cat3208, catapillar, caterpillar, diesel, diy, fox, fuel, heated, injector, line, pick, pump, reviews, sale, tank, truck, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
