Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-04-2003, 08:58 AM
jrocco's Avatar
jrocco jrocco is offline
Garage is empty, add now
jrocco is starting off with a positive reputation.
EGR Valve - How to replace?
Is there any way to remove the EGR valve on a 4.6L without pulling the engine?
Does anyone have any tricks to get around the very tight space to replace this valve?
Thanks in advance
__________________
1980 F100 Stepside - Wood Bed
351W .040 over, Comp Cams Xtreme Energy XE268H - 224 / 230 Degrees at 0.050 and 0.510 / 0.512 inch lift, GT40P Heads, Stainless Valves, 1.7:1 Roller Rockers, Headers
  #2 (permalink)
Old 05-04-2003, 05:43 PM
03f150man 03f150man is offline
03f150man is starting off with a positive reputation.
i'll consider your post as sincere. EGR's are just bolt off and bolt on parts. Is there something specific to your particular vehicle that makes it difficult to remove the eGR? it should be easy.
__________________
03F150man
  #3 (permalink)
Old 05-05-2003, 06:35 AM
jrocco's Avatar
Yes this is a sincere question.
This particular vehicle is a 1992 Grand Marquis and the EGR valve is so close to the firewall that I can barely get my hand in to just feel the top of the bolt heads let alone get any tools in there.
In addition I can't even see the tube that ties into the exhaust header.
I was hoping that someone had done this before and could give me a tip on how to remove this valve given the tight area to work in.
Thanks in advance for your reply.
__________________
  #4 (permalink)
Old 05-05-2003, 09:51 PM
that explains it, you mentioned 4.6L but i didnt know you were looking at an application for a car. I have no experience with your particular problem but maybe someone like Racerguy will chime in. you might also want to post on fordtech site
__________________
03F150man
Tags
2001, 2003, 46, 54, egr, f150, f350, ford, locate, replace, replacing, tricks, truck, v8, valvae, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
