You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just tried putting on the molded mud flaps for my wires 2013 explorer. The rear's went on NO problem.
Jacked up the front and removed the front wheels and the 2 plastic screws that you need to remove and re-use won't come out. It is like they are stripped. I have tired applying some pressure with a screwdriver to get the threads to engage but nothings seems to work. I don't want to break them.
Try putting the blade of a pocketknife under the flange of the screw and pry it gently as you turn it with a screwdriver. If the screw has threads, this will help them engage. It will work best with an impact driver, but being a plastic screw, you'd have to be careful.
It sounds like those are not screws at all. I agree to tru and get under the edge od the "screw" and pull out. They sound like the push-in typ pins that spread the fastener below. good luck, Jag
__________________
54 F100
55 Fairlane
68 F100
55 Crown Victoria
