another 460 build
another 460 build
well the old mercury block in my truck took a flop and is seized...buddy felt sorry for me and gave me the motor from his 85 supercab so long as i cut the truck up...
its a smooth running less than 60k miles motor...
it goes in my lifted 79 f250 4X4 with 39.5s
heres the parts list i have for it...was wondering if the parts are worth installing and what kinda power it'll make...wanna run pump gas
stock bottom end with new clevitte bearings and melling hv oil pump
lunati cam 214/214 w/.514/.514 with matched lifters
1970 429 timing chain and gears
D0VE heads with valve job and new springs and 1.7 roller rockers
either a edelbrock preformer rpm or a weiand stealth intake
a 2" carb spacer with an edelbrock 750- offroad upgraded
L &L shorty headers with 2 1/2" exhaust and 40 series flow masters
please remember i either have the parts laying around or there already in the truck and i don't wish to buy more..
do i need a stall converter for this motor setup?
this may help
275-300HP 460ci
Intake System:
Holley 600-750 vacuum secondary
Edelbrock Performer (non-RPM) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE
(No Port work. Just good 3 angle valve job.)
Intake valve size 2.08
Exhaust valve size 1.65
Stock rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5437 and Exhaust Lobe 5430
(Specs:240/250 adv., 196/206@.050, .476/.479 lift, 112 LSA)
Compression around 8.0:1
Stock crank
Stock rods
Standard volume oil pump
Stock oil pan
Exhaust:
Passenger cast-iron manifolds to dual 2.25" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
87-octane. Horsepower peak at 4,100 rpm. Keep redline to 5000 rpm.
300-325HP 460ci
Intake System:
Holley 750 vacuum secondary
Edelbrock Performer (non-Rpm) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job
(315-ish/180-ish cfm @.600)
Stock rockers.
Short Block:
Intake Lobe 5430 and Exhaust Lobe 5232
(Specs:250/268 adv., 206/218@.050, .479/.493. lift, 112 LSA)
Compression around 9.0:1
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Horsepower peak at 4,500 rpm. Keep redline to 5500 rpm.
325-350HP 460ci
Intake System:
Cylinder Heads:
Stock rockers
Short Block:
(Specs:250/268 adv., 206/218@.050, .479/.493. lift, 110 LSA)
Stock crank
Stock rods
Stock oil pan
Exhaust:
1.75" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
350-375HP 460ci
Intake System:
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Keep redline to 5500 rpm.
375-400HP 460ci
Intake System:
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job and port match
Stock rockers.
Short Block:
Comp Cam XE262H Hydraulic flat tappet cam or equivalent
(Specs:262/270 adv., 218/224@.050, .513/.520, 110 LSA)
Compression around 9:0:1
Stock crank
Stock rods with good bolts
Stock oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6000 rpm.
275-300HP 460ci
Intake System:
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
300-325HP 460ci
Intake System:
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
325-350HP 460ci
Intake System:
Cylinder Heads:
Stock rockers
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
350-375HP 460ci
Intake System:
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
375-400HP 460ci
Intake System:
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Exhaust:
Summary:
appriciate the heads up info... turns out my heads a 1969 castings and not 70 my machine shop even tryed to buy them off me.. and i noticed most of the motor buildss you listed use 91 octane.. is it possible to build a 400hp 460 on pump gas with the parst i have and what would i need to change??????? at 4.25 a gallon and 8mpg i really could use the savings..
biggest problem is the heads. the early heads don't gain any flow potential only higher compression. the higher compression gains you hp but also forces you to use higher octane fuel. To get into using lower octane your either going to need really dished pistons or get later model heads.
That's why I have for years tried to stop guys from saying the answer to power is D0VE heads. They don't provide more power during a rebuild and ONLY up the power on a head swap due to higher compression. There is no inherit advantage to the early castings on a street engine being rebuilt with new pistons.
flow benches don't lie. Scott at reincarnation tested them both ported and unported and there was very little difference.
He isn't the only one that has found that out. so yes I can say it.
Here you can look for yourself.
http://www.reincarnation-automotive....r-index-1.html
As noted, unported there is a 6cfm difference. That amount of difference would take a dyno with zero other variables to see.
And ported the D0VE increase to about 20cfm difference, still not enough to make a difference except on a dyno. And even at that it's only above .700 lift. Not many guys are running .700+ lift cams on the street, and those engines are barely streetable. Most usable cams are in the .500-.550 lift range and the heads for all intents and purposes identical ported or not.
Kinda like that list of engine builds done off of what manufactors say their parts will gain. It's a list not based of dyno or provable builds and rarely actually get there. But even that list mentions the heads can be either, only thing to make sure of is the compression ratio.
IMO the D3's are the only street head to use. If you don't want to or have a lot of money to invest just use the 88-93 FI pistons and get the block decked down, either way you will need to deck your block. Mill the D3's just to flatten them off, your not looking for anymore compression with those pistons. I ended up right around 9.5:1 with mine. Low enough it runs fine on 89 I have even ran it on 87 if I got to go a long ways. You can easilly tune the dizzy to make up for crap gas and not loose a whole lot. I don't run my D3's anywhere near stock. They have bigger valves, milled for studs & guide plates, spring seat cups, PC seals, bronze guides and are "sensible" ported. Seats blended, gasket matched, ex smog port removed, and widened a little where the head bolt passes through & thats about it to the ports. On a street head as far as porting goes you never want to trade off reliability for a few cfm's that wont be noticed.
Would have to make a lot of assumptions. BUT if your leaving the pistons down in the bore .010, and those are 22cc dish (I seem to think stock pistons in 85 were close to that, and with D3 heads that would be 8.25:1 so sounds right) should end up around 9.6:1 if the C9VE heads haven't been shaved any.
GASPIG88
08-22-2017 09:54 PM
glovemeister
03-19-2011 02:08 PM
just-n-time
01-22-2009 08:02 PM
66_in_ky
10-24-2008 07:29 PM
bearfoot_25
01-16-2004 05:15 PM
