Bronco fuel tank in 96 f250?
I installed one in my '88 F250 when I replaced the efi 302 with a carbed 460.I removed rear and side tanks to allow a true dual exhaust.Make sure to get the pick-up with the tank.If you're EFI,then you'll need one with a fuel pump.Get a Bronco tank/pick-up from the same year truck and the harness plugs right in.Another thing to consider is a plastic tank from Bronco Graveyard.It'll never rust.I made my own straps but they are available wherever you get your tank from.
300 Buster
10-11-2009 10:19 PM
oldhalftons
04-12-2005 10:33 PM
