Bronco fuel tank in 96 f250? - Ford Truck Enthusiasts Forums
Old 05-13-2012, 10:48 AM
RKraft's Avatar
RKraft RKraft is offline
RKraft is gaining momentum as a positive member of FTE.
I want to know if the 92-96 Ford Bronco tank will fit in my 1996 F250 for rear replacement. I know years ago I installed on in my 78 F250 & assuming I should be able to do the same here.
Randy
Old 05-13-2012, 01:07 PM
big vann big vann is offline
big vann is gaining momentum as a positive member of FTE.
I installed one in my '88 F250 when I replaced the efi 302 with a carbed 460.I removed rear and side tanks to allow a true dual exhaust.Make sure to get the pick-up with the tank.If you're EFI,then you'll need one with a fuel pump.Get a Bronco tank/pick-up from the same year truck and the harness plugs right in.Another thing to consider is a plastic tank from Bronco Graveyard.It'll never rust.I made my own straps but they are available wherever you get your tank from.
95 460 EFI swap wiring 95Bronco460 1978 - 1996 Big Bronco 18 08-26-2016 10:28 AM
Additional fuel tank FordTruckGuy96 1987 - 1996 F150 & Larger F-Series Trucks 7 07-15-2016 08:53 PM
Gas problem 96fordf250a 1987 - 1996 F150 & Larger F-Series Trucks 2 07-04-2016 12:45 AM
Rear gas tank maytea 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-01-2015 11:57 PM
Bronco frame the same? Krisx125 1994.5 - 1997 7.3L Power Stroke Diesel 6 12-08-2010 03:26 PM
Tags
96, bronco, f250, fir, ford, fuel, gas, large, rear, removal, replacementfor, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
