I am wondering wha my options are as far as trans mounts. I have a 61 4x4 and want tto drop in a 302. I have seen the bolt in motor mount but have not seen much on trans mounts. the bellhousing will need o be changed and anotherr mount added. Have not looked under truck o see if holes are on rans for a rear mount yet. any thoughts on this. thanks
we need to know what trans you are going to run.... they do make a C4-C6 trans crossmember, you can buy it through Dennis Carpenter for 60 bucks or so.
I just went through the trans and xfer case game on my 85 4x4. I modified a 78 Ford trans mount and made my own transfer case mount. I put a built 302 in mine with a T18 and a NP205. Ford truck mounts are easy. I'll try to get some good photos and post them.
the truck is stock and has a 223 6cyl with a 4spd trans. It is at my brother's house in ga and I haven't looked under to see if there is a rear mount for the trans. Trying to do a cost figure as far as rebuilding stock engine or swapping a 302.
