Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-12-2012, 11:08 PM
KAS300 KAS300 is offline
Garage is empty, add now
KAS300 is starting off with a positive reputation.
truck wont crank -- starter solenoid clicking
Working on getting a '57 F100 running that's been sitting four years. I've gone through a myriad of things to get it prepped before finally trying to start it up, so today all I needed to do was charge the battery.
I had a charger hooked up to the battery for most of the day today. Tried staring the motor, but the starter solenoid clicks and that's it. I suppose the solenoid could be bad, but could the starter possibly be the culprit?
  #2 (permalink)
Old 05-12-2012, 11:19 PM
FJones8668 FJones8668 is offline
1959 Ford F-250
FJones8668 is starting off with a positive reputation.
In my experience I have always thought that a clicking solenoid was a starter/solenoid problem; however, it has always come down to a corroded connections somewhere in the cables. I would check every connection for corrosion and good continuity before buying any replacement parts. I hope this is your problem, nice and simple!
Good luck!
  #3 (permalink)
Old 05-13-2012, 06:27 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
You said it has sat for 4 years and all that was left was to charge the battery, a battery that has sat for that long is junk, put in a fresh battery, clean all cable mounting points and see what happens.
  #4 (permalink)
Old 05-13-2012, 08:11 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Hope you're not trying to charge that battery.
__________________
Speed is a question of money. How fast "CAN" you go?
  #5 (permalink)
Old 05-13-2012, 10:56 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Hmmmm, Coos Bay Oregon. The corrosion blows in from across the Pacific and sticks to the electrical connections. Maybe jump across the big terminals on the solenoid after everything is clean and see if it cranks, that's what I'd do. Oh, and replace that old battery with the biggest one that will fit.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #6 (permalink)
Old 05-13-2012, 11:55 AM
All connections are clean, no corrosion. The truck hasn't been sitting at the coast the last four years, fortunately.
Yep, needs a battery. It's only putting out 10 volts. In my excitement & haste to get the thing started, it never even crossed my mind. Duh.
__________________
Kevin
1988 F250 4x4
-4.9L
-ZF 5-speed
  #7 (permalink)
Old 05-13-2012, 01:48 PM
New battery and she lit right off! Filled the garage with all kinds of nasty smoke, blasted a walnut out one of the tail pipes.....LOL it was quite the sight for a couple minutes.
Now she's purring like a kitten. Here it is:
Click the image to open in full size.
__________________
Kevin
1988 F250 4x4
-4.9L
-ZF 5-speed
  #8 (permalink)
Old 05-13-2012, 02:32 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Kevin that is a beautiful/handsome fridge (what ever the gender).
Oh and your garage is way to neat and tiddy, I could stop by and fix that.
Think I'll go straighten up my work bench. LOL
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #9 (permalink)
Old 05-13-2012, 04:56 PM
GB SISSON's Avatar
I can't even see my workbench
__________________
  #10 (permalink)
Old 05-14-2012, 01:18 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
thats a sweet truck
  #11 (permalink)
Old 05-14-2012, 08:43 AM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Nice looking truck. Glad a battery did the trick.
Is this your garage or did you just drop it off in some surgical suite to have the mirrors removed?
  #12 (permalink)
Old 05-15-2012, 07:49 AM
Thanks guys!
LOL yeah, that's my garage. Clutter gives me a rash!
__________________
Kevin
1988 F250 4x4
-4.9L
-ZF 5-speed
  #13 (permalink)
Old 05-15-2012, 01:40 PM
Juette's Avatar
Juette Juette is offline
1959 Ford F-100
Juette is starting off with a positive reputation.
Your truck is a beauty! I'm glad you got her started and i hope you are out cruising right now.
  #14 (permalink)
Old 05-15-2012, 04:26 PM
lwclark's Avatar
lwclark lwclark is offline
1960 Ford F-100
lwclark is starting off with a positive reputation.
Great stance! What's she got underneath?
__________________
Larry
1960 F100 Custom Cab Styleside
1966 MGB
I have no idea what I'm doing. May as well get started.
  #15 (permalink)
Old 05-19-2012, 11:33 AM
Quote:
I don't know a whole lot about the truck, but it has a Mustang II front end. For the powertrain, it has a 302 Ford mated to a C4 tranny.
__________________
Kevin
1988 F250 4x4
-4.9L
-ZF 5-speed
Tags
1959, 2002, click, clicking, clicks, conversion, cummins, edge, f100, ford, make, relay, replacestarterselnoidfordf100, solenoid, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
