Empty Weight... - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Empty Weight...
Old 05-12-2012, 10:55 PM
95e150CW 95e150CW is offline
95e150CW is gaining momentum as a positive member of FTE.
Empty Weight...
I was surprised at how light my recently purchased van is empty. Its a 1995 E150 Club Wagon with a 5.8L and an E4OD. I am ordering new custom springs and needed to know the empty weight. With a full tank of gas and my big *** it was under 4700lbs. That leaves over 2300lbs of payload. That's rather insane for what should be a 'half ton' vehicle. My E-Super box has crushed the scales at 19,500lb. Even empty its close to 10k.
Anyone else ever pull their van across a CAT scale?
Old 05-12-2012, 11:57 PM
surfref32 surfref32 is offline
surfref32 is starting off with a positive reputation.
yes, my '93 E350 5.8 E40D is 6100 with just a few tools and mostly empty cabinets. There's around 400 lbs in there maybe a little less.
My fully stocked '03 E350 5.4 E4OD service van is 8,000 lbs every day.
Old 05-13-2012, 12:25 AM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
Mine is 6600-7000 with me and most of my tools / ladders...but I have been around 11000 more than a few times , with stone or shingles / rubber ....my engine alone is 1000 lbs
Old 05-13-2012, 08:12 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I used Waste Management's scales once---free of charge too!
I just bought an 03 E250 extended body, completely empty apart from the factory rear sponge errr mat I mean. My first stop when bringing it home will be weighing it with a half tank of fuel to get a base line before refitting it for my work truck.
The current work truck tips the scales at 7800# with me and a half tank, loaded as it normally sees daily duty. It does have the fiberglass raised roof but I'm thinking my lighting, high-mounted rear heater and plywood/ABS ceiling panels more than makes up for the loss of metal in the factory roof.
I'll update this once my newer van is home.
Old 05-17-2012, 07:28 PM
LN323 LN323 is offline
LN323 is starting off with a positive reputation.
I haven't taken mine over to the scales yet, but I'm dying to find out. Mine's not empty being that it's a conversion van, but I'm hoping that I don't weigh much more than 5000 lbs. We'll see.
Old 05-17-2012, 08:42 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
mine weighs 8000 with all my equipment in it.
for those who have trouble finding a scale, here's a few points to start: truck scales along the highway, recycle yards, truck stops, quarries, and probably just about any other place that truckers load up every day, as they want to be as close as they can to their GVW without being over. not all of these are friendly to people randomly dropping in, but for the roadside scales (used for enforcement), any time they're closed, they're open for you. for recyclers, toss a couple hundred pounds of scrap steel in the back of the truck and sell it to them, they'll weigh you on the way in and on the way out
Old 05-17-2012, 09:49 PM
econolinemanor econolinemanor is offline
econolinemanor is starting off with a positive reputation.
My 02 E-150 4.6 low top Eclipse weighs 5,200, I had a 75 Cougar XR-7 that tipped the scales at 4,750. I bet the van would out run the 351w Merc..........
Old 05-17-2012, 11:48 PM
Quote:
LOL...
Yes, there is a recycler about two miles down the road from me. I'll go when I get a chance but the van is going through puberty right now (major overhaul). I'll get it weighed soon....
Old 05-18-2012, 01:28 AM
i used to have an 83 LTD (midsize model, same as a mustang) that weighed 4300 with all my stuff in it.
and one day i had 3 people ask me how many dead bodies were in the trunk... that happened to be the day after the air shocks blew out
Old 05-18-2012, 07:38 AM
JWA's Avatar
JWA JWA is offline
Just brought the new-to-me '03 E250 extended body, completely empty cargo bay except the factory mat. Caterpillar Certified scales say my total weight 1/2 tank of fuel & no occupants is 5300#.
This will go up considerable when outfitted as my work truck so it'll be interesting to watch those numbers change.
Old 05-18-2012, 04:18 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Hmmmm, this makes me want to make a trip to a quarry close to me, my ownership on my van says it weights 5900lbs empty.
Old 05-18-2012, 11:47 PM
Mark T-TB's Avatar
Mark T-TB Mark T-TB is offline
Mark T-TB is starting off with a positive reputation.
I found a sticker inside the rear doors (from the conversion company?- Elk Automotive) in our 03 E250... says weight is 55xx lbs, then lists the maximum passenger + cargo weight to bring it up to the 7000 lb gross weight max.
I was hoping to get it weighed at the Mobility shop last week, but forgot to ask then would have an idea if the 55xx number is close. We have the lift and 1 transfer seat base mounted inside, along with the 1 rear seat that folds flat like a futon...
Old 05-19-2012, 07:45 AM
JWA's Avatar
JWA JWA is offline
Mark am I misreading your numbers there? We both have '03 E250's (mine is ext body) and our max GVW should be 8600#. IIRC along with your lift and seat you have fiberglass wheel flares/running boards too?
John your registered weight of 5900# is probably spot on---if its your War Wagon the E350 and extended body would add that 600# over my bare & empty E250, extended body.
Old 05-19-2012, 11:01 PM
Mark T-TB's Avatar
I have "questions", too, but nothing definite for answers at this point.
I'll try to get some pictures (later) of the various "stickers" and post them up... I was surprised to see the 7000 gvw after reading on this forum [somewhere] that E250 is 8600 gvw???
Yes, our van has the fiberglass flares and running boards, but no "middle" seat. It also has a heavy steel "shield" under the gas tank and an extra [dead] battery under the floor 'way in the back (now disconnected, hopefully soon to be removed).
Mark
Old 05-20-2012, 07:30 AM
JWA's Avatar
JWA JWA is offline
Here's my door sticker tag:
It'll be interesting to know what you have on your E250.
setting up a WDH on a scale meborder Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 15 07-12-2016 12:11 PM
Actual weight traveler1234 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-22-2016 11:12 PM
06 E150 ride height firepop5 1968-2013 Full Size Vans 9 01-06-2016 11:32 PM
Scale weight - can it possibly be right??? FatOldGuy Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 12 12-18-2015 07:29 PM
'97 Club Wagon Chateau...good deal or not? misteramx 1968-2013 Full Size Vans 16 01-10-2007 02:08 PM
Tags
1980, 2002, 60, 73, actual, bronco, curb, diesel, e250, f250, ford, full, scale, size, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
