Empty Weight... - Page 2 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Empty Weight...
Old 05-20-2012, 10:09 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
for what its worth, i know that in the F-trucks, there were "light" and "heavy" F250s. i happen to own a 6000# F250, while others are 8000 or more.
that said, his sticker of 7000 may well be legitimate.
Old 05-20-2012, 10:12 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
The light Duty and HD F250's or E250's are easy to spot if the hubcaps are missing.
The LD have the semin floater axle, and the HD has the full floater.
But that doesn't apply much anymore in the van world. I seen alot of Diesel Ambulances E350's with semi floater axles, witch is stupid!
Old 06-03-2012, 08:50 PM
Mark T-TB's Avatar
Mark T-TB Mark T-TB is offline
Mark T-TB is starting off with a positive reputation.
The Ford sticker (driver door jamb) says 7900 lbs GVW. I need to double-check, but I think the Ford Owner's Manual lists an E250 "Conversion" at that GVW.
There is another sticker from Elk that appears to have info for an E150 (wrong size & type tires, etc)... so it seems that things at the conversion company were a little "fast and loose" - unless it was a "Monday Van"(?).
I'll eventually get some pix...
Old 06-04-2012, 07:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Mark I look forward to seeing your actual Ford stickers----must be something to John's ideas about Light Duty vs Heavy Duty E-Series?
Old 08-06-2012, 01:34 PM
Mark T-TB's Avatar
Stickers
Finally - got a decent picture of the Ford tag (one of the kids took it with an I-phone, I could not get my Canon to focus on it for some reason).
The Ford tag from the door jamb:
The "other" sticker inside the rear door - from Elk or Roll??)
Hard to believe that this beast is only 7900 GVW, the Expy is 7300 with seemingly smaller everything (and only needs 35 psi in the "P" 17" tires).
Old 06-02-2014, 01:32 PM
Mark T-TB's Avatar
fwiw, I decided to eliminate the sticker with the hand-written numbers (even tho it said "do not remove" - hey, it's not like it was on a mattress) since the info was incorrect...
I'll go with the sticker from Ford for actual data.
Old 06-05-2014, 04:16 AM
EwagonJeff EwagonJeff is offline
EwagonJeff is starting off with a positive reputation.
FWIW Dropped off some scrap a couple weeks ago, on the way out with 10 gallons gas (filled afterward and put 25.x in) it weighed 5410 WITHOUT me in it. It's a '98 Chateau Club Wagon, all 3 rows of seats were in it. No running boards, nothing aftermarket.
Old 06-05-2014, 06:43 AM
JWA's Avatar
JWA JWA is offline
I have no idea what those numbers could possibly be referring to---makes absolutely no sense. Although if the Matress Tag Police get bored, looking to expand they might come lookin' for miscreants like YOU!
Quote:
I'd have thought a CW with all seats would have weighed more than that---my empty E250 EB was a whopping 5,300#, no full sized spare mounted underneath.
I'm now at 7,600# as a daily driver outfitted with Snap On tool box, various other van-specific metal shelving and glass working tools, supplies and parts.
Old 06-06-2014, 03:20 AM
Quote:
When you think about it, it's about right, I've seen published curb weight for an E150 right around 4800, obviously thats a base cargo, standard body, maybe without even AC? Maybe even an empty gas tank, dunno how they do the curb weight.
Now add the insulation and side panels, carpeting, blower motor. evap and heater cores for the rear HVAC, side glass then the seats, just guessing a few hundred for all that. The CW buckets are around 70 each (weighed one on a bathroom scale) plus the big steel bases, figure thats 150 for the second row, third row bench I'm guessing around 100lbs. It's the plane one, doesn't fold or recline. Theres your 5-600 over curb.
For yours the 5300 sounds right if by "empty" you mean besides no cargo, it is also a cargo van or you removed the 2nd & 3rd row seats. I figure around 250-300 lbs more for the EB with the extra sheet metal, glass and frame, then the extra weight from what ever bigger heavier duty suspension parts of a 250 vs. a 150
Old 06-06-2014, 06:21 AM
JWA's Avatar
JWA JWA is offline
Yes sir, "empty" meaning just as delivered from factory even with the pathetic 225R75-16 tires. (Those have been changed out for Michelin 245R75-16's.)
There was no full sized spare installed when weighed immediately after my purchase. I figure that adds at least 75#.
Old 06-06-2014, 10:18 AM
Mark T-TB's Avatar
so... std body E250 "conversion", no middle seat, 3rd row "futon", transfer seat, fuel tank shield, and single-post lift (I was told 300#), empty gas tank - the 5581 sounds like it may be an actual weight from a scale... of course it could also be prior to the RollX conversion(?).
Old 06-06-2014, 10:58 AM
JWA's Avatar
JWA JWA is offline
Mark I would say that's a good guesstimation for what you've got.
What that sticker was trying to convey still escapes me though.
  #28
Old 06-06-2014, 11:13 AM
Mark T-TB's Avatar
Thanks.
That is pretty much what I've been wondering for 2 years now
Calculating your REAL maximum towing capacity... 95e150CW 1968-2013 Full Size Vans 4 06-24-2012 10:56 AM
Unloaded / Empty Weight dakotajeep 6.0L Power Stroke Diesel 8 05-06-2012 01:10 PM
89 f350 empty truck weight 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 5 04-11-2012 06:11 PM
Overloaded F250? wallboyz Toy Hauler Towing; Fifth Wheel & Bumper Pull 31 11-22-2011 02:45 AM
Curb Weight For A 63 Deluxe Club Wagon jschira Ranchero & 1961 - 1967 Econoline 3 01-05-2010 10:13 AM
Tags
1980, 2002, 60, 73, actual, bronco, curb, diesel, e250, f250, ford, full, scale, size, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
