1978 Grumman Stepvan - Ford Truck Enthusiasts Forums
Old 05-12-2012, 09:34 PM
Texas cookie Texas cookie is offline
Texas cookie is starting off with a positive reputation.
Hello,
I'm new to this and I'm hoping for a little direction on the engine of this Grumman truck I'm in the process of purchasing.
1978 -10 FT GRUMMAN ALUMINUN STEPVAN, WITH CURB SIDE SERVING WINDOW,INSIDE FLUORESCENT LIGHTS, FORD V/8 ENGINE, AUTOMATIC TRANSMISSION,SINGLE REAR WHEELS,TRAILER HITCH
The truck runs but has carborator issues, there is a pin missing that keeps the connector from opening the throttle plate so you sometimes have to manually play with it to let air in. Its an original Ford engine and once it gets started it runs pretty well. Is this something that could be fixed easily or should i consider an engine rebuild
Old 05-12-2012, 10:05 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I think you're kinda in the wrong forum but we'll give it a shot in the dark anyway.
First identify what engine you have! It's gasoline, right? Take some pictures and compare them (using Google) with a 302 Windsor, the 351M/400, and the 460. Once ya figure that out or at least have a clue, then post your inquiry in the engine forums of FTE.
Carb pin or engine rebuild? Wow. I know which one I would try to fix first.. a carb can be as little as $25 from a wrecking yard. An engine rebuild or remanufactured engine starts around $1000 for a short block.
We can help only if you help yourself and help us understand what you have. You've got alot homework to do to provide more information.
Old 05-12-2012, 10:13 PM
HIO Silver's Avatar
Hmm... You sure it's a V8? I just did a quick Google search and it's likely equipped with a 300 cubic inch inline six cylinder.
Old 05-13-2012, 01:29 PM
lafermedavid lafermedavid is online now
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
Grumman
I had an 81 grumman with a 350 chevy quadra-jet,the fuel cost made me get rid of it in 2000 had it for 15 yrs,you can find alot stuff for them if you find junk yards that carry big trucks
Old 05-13-2012, 06:29 PM
Thank you, HIO Silver you have given me a lot to think about and i definitely need to do some more research. I will be heading down to take some pictures of the engine tomorrow and i will post the questions in the engine forum.
Am I Crazy? Step Van on X chassis SeniorBliss Excursion - King of SUVs 15 10-24-2016 02:56 PM
1959 Ford P350 axle ratios Lahti35 1957 - 1960 F100 & Larger F-Series Trucks 11 08-03-2016 11:00 PM
New here, looking at a '73 step van moroza 1968-2013 Full Size Vans 4 05-02-2016 09:19 PM
1973 G500 F500 F600 Hydrovac brake question: Self Adjusters wondervan Large Truck 3 04-22-2016 01:06 PM
P 350 grumman olsen aerobilt all aluminum body 1963 galvanized knight 1961 - 1966 F-100 & Larger F-Series Trucks 48 02-03-2016 11:27 PM
Tags
10, 1960, 1979, axle, beam, buy, ft, grumma, grumman, panel, sale, step, truck, van, virginia
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
