I need an accelerator linkage assembly
05-12-2012, 08:20 PM
I need the swing arm assembly that bolts to the firewall. 1954 F100, 223 six.. The aluminum bolt bracket on mine is broken from the hinge. Got one?
05-12-2012, 08:31 PM
Eh... I may. Need to see what i did with them. I'm on the Left coast, so shipping may cost you an arm or left nut. See if anyone on the right coast chimes in. Lots of FTE'ers out your way, should be able to help you out.
05-13-2012, 07:58 PM
05-13-2012, 09:00 PM
on
Quote:
Originally Posted by
turnrjr
All the major suppliers sell them if you can't find one used. I found a new one on ebay for $20 + shipping. Good luck.
05-14-2012, 07:01 AM
I'm watching ebay. There is one on there now but it is not the right configuration for the 6 cyl. There are several different ones. Thanks.
05-14-2012, 11:02 AM
Might be able to score you one in the next few days IF it is the same from a 53 with 215 six.
05-14-2012, 06:37 PM
I checked the parts catalog. It's the same part number for the 223 and 215.
05-17-2012, 05:57 AM
05-17-2012, 12:37 PM
How many do you need? Do you have a picture, so that I can reference the several assemblies I have here?
05-17-2012, 05:45 PM
WmJoe see that the aluminum bracket is busted. The small holes are where the PO patched it up. The radius from the hinge to the end hole on the carb end is 5 3/4". The radius from the hinge to the pivot on the other end is also 5 3/4". If you have one I'll PM you. Thanks.
05-17-2012, 06:05 PM
I have several of that type of linkage assembly. How many would you like?
05-17-2012, 06:25 PM
WmJoe, I sent you an email.
05-29-2012, 07:58 PM
on
I have one I jsut took off my 1950 for a 6 cyl. It is snapped off right at the gas pedal. I will send you a private message.
05-30-2012, 01:58 AM
05-30-2012, 05:10 AM
I think I'm all set. WmJoe is working on one for me. Thanks.
