Air Conditioner issues with engine under load
The Air Conditioner on my 03 6.0 F250 works great!! EXCEPT when I put the engine under a load. Yesterday, I was pulling a trailer max speed of 40 MPH, with the transmission in tow mode. The air conditioner would not work at all. Today, no load, air conditioner has no problem.
Any ideas?? as you can imagine Air Conditioning in Tampa is "must have"
air conditioner trouble under load
Ok,, belt was replaced about 25K miles ago, not an easy job. I am not sure how to check the tensioner,, but it looks ok. As far as the fan clutch,, I hear it engage and disengage so it appears to be working.
I thought about a temp issue, so I checked the EOT and ECT while under load. I was surprised that they were real good,,, 197 ECT, 203 EOT,, per scan guage. Outside temp was 92.
wat about the vacuum pump? would tat be a problem, guys?
also, wat about the reservoir next to the vacuum pump? tats hvac-related. also, if ur vehicle has climate control, then i'd pay attention to the vacuum lines too. could have been chafed or accidentally unplugged.
sorry guys, jus covering all the bases. or maybe i might be barking up the wrong tree.
air conditioner problems under load
Any loss of coolant?? that is an interesting question.
I am losing coolant, about two or three drops per night. less than one teaspoon a night, all on the passenger side. I think it may be a heater hose issue,, I just havent been able to really see where its leaking.
But in 4 months of watching this, i have yet to add any coolant to the system.
Talbotsgt
04-27-2012 08:51 AM
