Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-12-2012, 02:25 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
Garage is empty, add now
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
53 Flathead V8 Spark Advance
53 flathead .003 bore Merc crank mild cam
tripple deuce carb progressive linkage
Do I need to change the distributor to a centrifical advance type?
Speedway has some, but one says you have to drill out the hole? (DON'T WANT TO ATTEMPT THAT)
F100 Truck still in restore mod, so I haven't driven it yet.
__________________
Steve
53 F100 Flathead 8
Listen to advice and accept instruction, that you may gain wisdom for the future.
Proverbs 19:20
  #2 (permalink)
Old 06-09-2012, 03:46 AM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
I went to the mallory system, completely mechanical advance. Highly recomended
__________________
Some nights you just have to realize your gonna be slaying a Dragon and not saving the Princess
  #3 (permalink)
Old 06-09-2012, 06:43 AM
ssj7kids's Avatar
Snowking,
Where did you get it from?
  #4 (permalink)
Old 06-09-2012, 09:24 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe is starting off with a positive reputation.
You do need to change distributors due to the multi-carbs and the cam change. Lots of people complain about the stock 8BA distributor, but it works fine on a stock engine.
  #5 (permalink)
Old 01-01-2013, 08:05 AM
GenoCrusin GenoCrusin is offline
GenoCrusin is starting off with a positive reputation.
It’s functional if you can get past the Chevrolet stench
A Chevrolet point distributor (same rotation, parts availability and similar dimensions)
Lathe
‘70s Chrysler electronics/ reluctator and pickup
Adjustable Vac advance can
Looks almost stock and virtually bulletproof outside of having to carry a spare ballast resistor (the problem with that system). It can be done very easily in a couple of hours. The machine work is pretty straight forward. Just measure the flatty and cut the Chevy accordingly using the flatty gear. Attention does have to be paid as to the placement of the pickup coil on the Chevrolet advance plate (rotor phasing in a round about way)
Any aftermarket parts house has advance kits for the Chevy and adjustable advance cans for the old point dist.
“set” the mechanical curve using a tachometer, timing light and degreed/marked the stock wheel. Only as a starting point using the ford FSM as a reference.
“T” a vacuum gauge into the Vacuum advance line to read @ part throttle/highway cruise to set the can (pinging). The guage is a reference only for tuning
I guarantee you will be amazed at the responsiveness.
  #6 (permalink)
Old 01-01-2013, 12:04 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
One more item on the Chrysler system, air gap on the reluctor is critical and must be set with a non-magnetic feeler gauge.
Another tidbit for all. The Lucas "Constant Energy" ignition used in the last of the MGBs and retrofitted on earlier models with a failed Opus system uses a Chrysler style pickup, the same coil as the Opus and a GM HEI 4 pin module in a case/heat sink. It (even though it is GM) is infinitely more reliable than the Chrysler system.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #7 (permalink)
Old 01-01-2013, 01:55 PM
Not too sure if the Lucas is compatible with the Chrysler 8 reluctor. Whole bunch of possible issues +0- (null) to fire the module (rotation etc). Interesting subject though.
I built this about 15 years ago and still on the ‘49. I think I did about 5 or 6 of them back then using the KISS principle of hot rodding. I could never find another Chevrolet “Mag Pulse” pickup I used on the Vega would have made the whole thing a lot easier.
As far as “reliability” that particular system was used on every Chrysler product for almost 20 years, why I chose it. The Chrysler racing parts book gave the specs on their various modules (about a full page). Pick the one that suited my application.
My daily driver (73 Vega big head duel quad 355 with a light wheel and 4 speed) had the Chrysler “gold box” 7,000 rev limiter and chip suppression using the corvette “mag pulse” (actually a Capacitive Discharge) Pickup (rotation/null same). The Acel quart fruit jar coil (Yellow) was recommended by Chrysler in their speed parts book. Great piece for it’s time.
Most guys tossed the Chevrolet module. Above 5500 the dwell time/coil saturation fell off pretty quickly
I was going to do an HEI for the flatty but didn’t like the physical size, never could find the flatty under that big cap. With the duel quad on the Vega was out of the question
  #8 (permalink)
Old 01-01-2013, 09:02 PM
1986 Ford F-350
william.a.vose
The Lucas pickup ohms out to be the same as the Chrysler. I worked for Tysinger Motors in Hampton VA, at the time they sold Mercedes-Benz, Dodge, MG and Jaguar. Since the flathead rotates opposite the OHV Ford V8s with DS-I or DS-II you can't use them. For a non-vacuum advance conversion, look at the late Chevy marine applications, it is an HEI with external coil and a relatively small cap. You might be able to just use the marine module in place of the computer controlled advance system. The Remote coil model uses an "E" core coil like the Ford TFI system. I have an HEI converted setup for a Corvair using an early 2.8L Chevy distributor adapted to a Corvair drive. It uses the "E" core coil with an internal to the distributor module.
On the MOPAR stuff, I got real good at changing boxes and ballast resistors on them. The early ones were probably the most failure prone electronic ignitions out there.
__________________
Tags
53, advance, f100, f250, flathead, ford, shooting, spark, trouble, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
