Pump timing
on
hard to say without a timing # to work with.
could be fuel is too high,could be timing too advanced.could be a combo.
it's tough to tune without a meter and pyro.it can be done,but it requires several hard test drives and some wasted fuel.
i would guess your timing was really retarded and the fuel turned up due to lack of performance to try and compensate.if your economy was horrible since adjusting the fuel last time,that would be a sure sign of what happened.
rolling black smoke is never normal.it's not only bad for our kids and grand kids,but it does nothing for performance gain,and it's hard on our wallets,as all it is,is incompletely burnt fuel.it also causes very high egt's too,which is no good for the engine.
some is always normal until the turbo spools up,but puffing a large cloud or rolling,that's expensive diesel fuel getting nothing done for ya.
I have not touched the fuel, but advanced the timing without a meter. Egt did not seem to be affected. I recently straight piped the exhaust and EGT's are a little lower. I marked my pump before I advanced it, do you think I should retard it back or turn the fuel down a flat. Side note, I tried to turn the fuel up prior to advancing the pump and could not get it to move. Could it be maxed out and need to be turned down now that I advanced the timing? Thanks for any insight.
FlatHat Ranch
01-13-2014 11:47 AM
