Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-11-2012, 08:32 PM
autoxbird autoxbird is offline
1991 Ford F-250
autoxbird is starting off with a positive reputation.
Twin tank woes
'91 F250 460, LB, twin tanks. The front tank works fine, the rear tank runs fine, but fills the front tank. I'm running out of parts to replace. So far, I've replaced the front pump, rear pump, and the updated external check valve on the front tank. Best as I could guess, the only parts left to replace are the rear check valve and the dash switch. What else could I be missing?
  #2 (permalink)
Old 05-12-2012, 02:32 AM
GuitarJesus GuitarJesus is offline
Garage is empty, add now
GuitarJesus is starting off with a positive reputation.
Auto,
from what I understand it's not the pump itself you have to replace, but the delivery module itself that controls the check and shuttle valves. I am doing the same thing myself, just bought a rear complete module (pump, delivery module, and sending unit). Also just bought the rear unit.
So if you simply replaced the pump itself, you need to replace what aftermarket companies will consider the sending unit. From what I've gathered (and somebody please correct me if I'm wrong), Ford considers the sending unit just the float and electrical connection for it. But aftermarket companies consider the inlet tubes (top piece of module) and the float to be the sending unit.
I could be wrong, but I think that's where you might need to look. By the way, the external check valve, where did you get the part to "update it"? I'd like to get that part so I don't have to worry about the delivery modules going haywire on me later.
Jeff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
