Chunk taken off rear yolk
Old 05-11-2012, 06:48 PM
SPCMarty's Avatar
SPCMarty
SPCMarty is offline
While changing the rear driveshaft ujoint, I managed to take a chunk out of the yolk while pressing out the cup. Apparently both "ears" had been dented slightly. So I used a grinding wheel to remove the bent metal so the other cup would press out.
Anyway, I sadly had to use this yolk. My question is, is the balancing on these precise enough to explain why I still have some shaking going on, once I hit 55+mph.
Old 05-11-2012, 07:30 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
If the vibration is from 55mph and up, my guess would be a tire and/or wheel out of balance.. The drive shaft should shake at a much slower speed like maybe 20-30 mph.
Old 05-12-2012, 07:23 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
You can use a hose clamp around the driveshaft to change the balance. If the vibration gets worse or gets better, you know it is the driveshaft. I would expect any vibration from the driveshaft to get worse with increased speed.
makemeknowit
Modular V10 (6.8l)
16
11-04-2018 08:48 PM
bigric
01-11-2012 10:09 AM
98SurplusExpy
1999 to 2016 Super Duty
02-06-2010 04:48 PM
97ExpGuy
1997-2006 Expedition & Navigator
02-09-2009 07:35 PM
fd1109
13
12-05-2007 06:32 PM
Quick Reply: Chunk taken off rear yolk
