Battery idiot light
Battery idiot light
So I took my alternator to a trusted electrical shop. After I installed it the battery light stays on now all the time. When the truck is off, the battery is at 12 volts. When the truck is running the read on the batteries is 14.3. Why would the battery light still be on if it appears to be charging? Thanks!
Really I have heard that 14v is what the alternator should be charging the batteries at, but I could have heard wrong. Any one else have an idea?
I'm not so sure about that... EVERY vehicle I've ever seen/checked/used/tested/etc. read 13-14V while running and MAYBE 12V after sitting overnight. Sounds normal to me, but as to why you still have a light, I don't know.
A fully charged battery should read around 12.6 V without the engine running, but that will drop as the battery sits. The design average voltage wth the engine running is 13.8 V, but that number can vary depending on load, engine speed and other factors. 14.3 V is on the high side of normal, but not unusual to see.
In any case, the battery light should not be on. I would return the alternator to the rebuilder and have them double check it.
Chris
Chris
Alabama Mike 83
20
07-09-2017 07:11 PM
jwhopson
13
08-25-2012 02:20 AM
