Powermax...... No more Howling!! - Ford Truck Enthusiasts Forums
Old 05-10-2012, 08:52 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Angry Powermax...... No more Howling!!
Powermax in.
All back together. Took it for a little drive.
First, smoking some. I'm thinking it is burning off new oils and stuff from manufacturing . I see zero oil coming from either place, feed line or the drain tube.
Now, when I had it out on the street, I laid into a little bit. Like 5.5 lbs. of boost.
It howls like a train horn, I let off and it stops. Lite throttle and it doesn't do it.
Could I have not gotten the up pipe totally connected right? It sure looked good from my angle.
Any thoughts folks?
Old 05-10-2012, 09:28 PM
04Muscle350 04Muscle350 is offline
04Muscle350 is starting off with a positive reputation.
Check your up pipe for any soot at the connection. I would lean towards a possible leak there. See if you can feel any air while idling or hear any sign of a leak. How far did you drive it?
Old 05-10-2012, 09:38 PM
maybe a couple miles. Basically, around the block.
Old 05-10-2012, 09:46 PM
Look for a leak at the uppipe and feel for air. If you can't find any evidence there then try driving it a little further and see if it needs to relearn.
Old 05-10-2012, 09:49 PM
Yeah, I am going to stop by Harbor Freight in the morning and grab a ratchet strap, and see if I can't get it any closer. Man, I sure thought it was right where I needed it. But, I'll see if I can do a better job.
Thanks for your input.
Old 05-10-2012, 09:57 PM
I was fortunate enough to seat my 03 turbo first time when installing and didn't have any leaks etc. I also put on a new exhaust at the same time so the downpipe was more flexible cause it would pivot and stuff easier. Lol
Old 05-10-2012, 10:10 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Driven they can look real close but if its not perfect it will leak. I wouldn't use a ratchet strap just lousen the up pipe bolts and it will pop right in most the time. Hell i wish that was my only problem.
Old 05-10-2012, 10:12 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
When you said Howel I thought you ment at rear exhaust pipe
so the howel is coming from the engine Bay???
If so then probably Ypipe to turbo connection
That turbo can be a PIA
I set turbo in the Pedistall and the Ypipe is the very first thing I hook up
I set it in pedistall then Eyeball the Joint and found to make a perfict reveal around the joint I had to push the Ypipe towards the firewall. So then I smeared antiseize on the Marmon clamp flanges and Installed the Marmon clamp Loosely on the Joint. I then setup my air ratchet on the clamp bolt and Gave it the same push (what it took to make the reveal even when I had the clamp off) toward the Firewall as I Sucked clamp tight with air ratchet and worked like a Dream. once you get that your Golden
Old 05-10-2012, 10:15 PM
uofmgriz's Avatar
uofmgriz uofmgriz is offline
uofmgriz is gaining momentum as a positive member of FTE.
worst case scenario...a little dawn and water in a spray bottle will work wonders...shoot it and look for the bubbles...works wonders for finding air leaks...and may do a little cleaning too!
Old 05-11-2012, 01:21 AM
cay5628's Avatar
cay5628 cay5628 is offline
cay5628 has a great reputation on FTE.cay5628 has a great reputation on FTE.cay5628 has a great reputation on FTE.cay5628 has a great reputation on FTE.cay5628 has a great reputation on FTE.
I second that, I was chuckling about the howl when I first read it, I too thought the really cool, screaming banshee man this thing is wicked a$$ fast kind of howl; not the leaking air kind of howl that sucks the life out of you after all that work kind of noise.... Sorry to hear it is not meant to be yet. Best of luck getting it seated properly.
-Mark
Old 05-11-2012, 03:11 PM
Well, here I was so concerned about the up pipe getting on right, that I didn't pay enough attention to the down pipe connection!
The down pipe was the culprit. No more howling.
But, she does whistle more. Nice having Her back on Her feet!
Thanks you guys!
Oh, I had purchased some smoke bombs on sale a few years ago (after the 4th of July) just for this very thing. Dropped one in my shop vac. Worked well until the dang wind shifted and filled the front of the truck with smoke!!!! Well, it was a good idea any way!
Old 05-11-2012, 03:12 PM
And , no , there isn't a video called "the red neck way to test for leaks" Sorry.
Old 05-11-2012, 03:24 PM
cay5628's Avatar
Sweet! Glad you are rolling again. when you get some break in time done, tell us how that Powermax does.
Powermax video Hossfly05 6.0L Power Stroke Diesel 1 06-17-2015 05:06 PM
"New" engine-to Powermax or not to Powermax outdoormaniac 6.0L Power Stroke Diesel 8 03-02-2014 07:23 AM
VGT solenoid ?'s Nice Work Truck 6.0L Power Stroke Diesel 7 06-03-2013 01:52 AM
Howl at idle only.. WTF now??? motopsyko32 Excursion - King of SUVs 10 05-30-2012 07:40 AM
my truck is howling JIMMY663 2004 - 2008 F150 3 02-02-2008 05:02 PM
Tags
2003, 200820092010, 60, engine, f250f350f250f350, ford, gt3788va, horn, howling, oklahoma, powermax, reviews, train, truck, turbo, whistle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
