Picture of my New EGR Valve (Carbon Chunk)
Received 1,446 Likes
on
Troy its common enough to write an article about it . Click here.
EGR marbles is caused by a slow leakin EGR cooler.
I agree the EGR is worthless
however, deleting it causes issues with certain trucks. Especially those with the latest PCM strategies from Ford (06 & 07's...and earlier's that were updated). It causes the fan to act wrong...if not at all.
I have my EGR turned off with my SRL tune. I'm sure a little gas flow still exists past the valve, but nothing like when it's operating per factory spec
If I ever have to get inside the motor, I plan on getting the BPD round cooler.
on
What's strange is when I changed the EGR valve my intake manifold looked dry and I typically change the coolant every 2 years and the coolant level never drops one bit.
Now that I thought about it a little more the shape of the carbon chunk had to be formed in the intake manifold (one side being very flat) and not the EGR cooler itself.
Troy I'm in the same boat. No coolant loss, no wetness in or around the valve, and the chunks were flat on one side. I'm going to call them wafers.
I was thinking it would be interesting to have them analyzed somehow to see what their make up is exactly. This would be the only way to rule out whether or not they contain coolant in them, but to be honest I don't see how they can.
As long as the EGR Valve is Plugged in it shouldnt affect the Fan. plus keeps PCM Happier.
Im deleated but the egr valve is installed and Plugged in and ZERO Fan Issues
Sounds like the way to go if you do the delete. I was under the impression the fan issue was still there for some reason. It is something I haven't looked into too much. I always figured I would just replace the egr/oil cooler at the same time and most likely switch to a non silicate coolant.
My main concern if I delete the thing is getting inspected. I don't need that headache. What do you think of the sneaky delete setup instead of a full delete?
I've read several cases where guys see cooler EGT's and quicker turbo spool time with that scoop/up-pipe change
With some of these PCM stratigy it looks for EGR Flow with the IAT2 sensor and the EBP Sensor to change Value when it commands EGR Valve open.
If they did a Visual inspection and egr cooler was gone then it would Fail This is why somee go with a BPD welded shut cooler or Blocker Plate cause this still looks like system is intact
Basicaly when they plug into the OBDII port they are just using the Sensors already on the vehicle to check Emission as the OBDII system monitors its own emissions and will turn on the CEL if there is a problem
I have thought about it, but here in Calif you have to bring it in every 2 years after truck hits 4 years old.
Can it be done ??????
#28
on
#29
My old valve is cleaned and ready to go with a new gasket kit.
Interestingly, getting the carbon wet with water completely changed them. It formed black sticky paste.
Think about it. If you sent the pieces to be analyzed an knew you didn't have a leak, would that be worth it? Especially considering the time and money it will take to replace your coolers. And thinking about it every time you're on a trip out of town wondering if your egr cooler is going to pop. I'd be willing to pay a couple bucks for some piece of mind. That's what the sgii is all about.
