I Was Wondering if Anyone Knew Where I Can Find This
Let's see if I can do this right..... or at all. Here is a diagram of the front bumper and it's components...... I think:
If this works, I believe #19 is what you are looking for? If it is, that is listed as a valence panel and they list 2 of them, one for 2wd and one for 4wd. 2wd is $102 and 4wd is $90 on their site, and again, I just don't see where 2wd or 4wd or would have any effect on that part. #20 is the valence bolt, both left and right and I guess they come with the panel because there is no price listed for that. If that is what you are looking for, just click onto www.Tascaparts.com in this post and it should take you right to the site, and navigation is pretty self explanitory, year, make, model and go to body hardware then bumper and components and there will be a list to correspond with the numbers describing parts and the prices for them. Not sure if you can find it any cheaper some where else, but you might, this is the only place I can think of besides a dealership and they'll probably want your 1st born for the thing. Hope this makes things a little clearer and it is of some help to you FordSter
Edit: Aahh, it did work! I learn something new everyday
Btw, the site Stewart H recommended is also good to go, same exact listings and prices so you could go there too. The 2 sites are such a mirror image of each other, I wouldn't be surprised if they were tied together somehow. I guess Tasca is not a supporting vendor? That was the only place I could think of, I had never heard of Tousley before today. Thanks for the input Stew!
I recommend Tousley because they are a supporting vendor here and I like to support the vendors that support the website. Tousley also supports quite a few Ford forums on the internet.
Steve at Tousley has always been very helpful to anyone that calls his parts department, whether a sale is made or not.
I know about Tasca because of their Ford racing history but no, they aren't a SV here.
Stewart
what exactly do you want?
Valence = the black part that bolts to the bottom of the bumper
make sure you order the correct valence for the year of your truck. The 04/05 bumpers are different from the 06-08 bumpers. They look similar outside, but the mounting hardware is different (as well as foglights)
There are 2 of them
4x2 and 4x4. You can see how they are different. Each bolts up using same hardware (except tow hook area)
Bumper grille cutout4x2 and 4x4. You can see how they are different. Each bolts up using same hardware (except tow hook area)
04 and 05 trucks came with a small insert on the outer edges that matches the honeycomb grille
06-08 trucks do not
the shape of the bumper opening is different and you cannot use 04/05 parts on the later trucks. Once upon a time I had links to aftermarket 06-08 inserts....but I haven't had my F-150 for 3 yrs and lost all my links
06-08 trucks do not
All of the Ford online parts sites I've seen use the same interface, probably supplied by Ford IS department for the dealerships, I would guess.
Stewart
Stewart
U hook valence? I'm sorry FordSter, I'm not trying to be smart with you, I just want to make sure we are talking about the same thing and to try and steer you in the right direction. You are talking about the valence that surrounds the 2 tow hooks below the bumper, right? If so, I'm surprised you don't already have that on your ride, unless it got tore off or something. It's really hard to tell from the pic of your truck cause it's dark or black below your bumper, it almost looks like that valence is on your truck.
Stewart
Stewart
If this works, I believe #19 is what you are looking for? If it is, that is listed as a valence panel and they list 2 of them, one for 2wd and one for 4wd. 2wd is $102 and 4wd is $90 on their site, and again, I just don't see where 2wd or 4wd or would have any effect on that part. #20 is the valence bolt, both left and right and I guess they come with the panel because there is no price listed for that. If that is what you are looking for, just click onto TascaParts.com in this post and it should take you right to the site, and navigation is pretty self explanitory, year, make, model and go to body hardware then bumper and components and there will be a list to correspond with the numbers describing parts and the prices for them. Not sure if you can find it any cheaper some where else, but you might, this is the only place I can think of besides a dealership and they'll probably want your 1st born for the thing. Hope this makes things a little clearer and it is of some help to you FordSter
Wow that is interesting, did not know that those models did not come with the valence on them. Sucks to find out that Ford cheap's out on some people. Like I said before, I learn something new everyday.
#30
Yeah, the valence and hooks came factory, I just assumed they all came that way. Your welcome on the part, I figured that's what you were looking for after I realized you didn't want the bumper. As you can see there are a couple of places you can get that from. Good luck and let us know how you made out
