4.6L Mysterious Misfire - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 05-10-2012, 05:00 PM
LeeLeadingham LeeLeadingham is offline
LeeLeadingham is starting off with a positive reputation.
Hello all.
I have a 1998 Ford Expedition EB with the 4.6L in it.
I have replaced all the plugs, and wires, as well as the coil packs. It seemed to run a little better, but still yet have a misfire.. It's not all the time, just intermittent.
Also noticed, while driving down the back roads, doing about 55 or so, it starts to buck or surge while off the gas, or holding steady throttle.
Any help would be greatly appreciated!!
Old 05-10-2012, 05:01 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Need to pull codes.
Old 05-10-2012, 05:02 PM
I have, no codes after replacing the plugs, wires and coil packs.
Just comes and goes. Mainly after its up to operating temp.
Old 05-10-2012, 05:06 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Check for pending codes.
And have you checked the infamous PCV elbow at the rear of the intake manifold?
Old 05-10-2012, 05:09 PM
I've checked every computer option avail. We have a 7000$ snap on computer at work, and we ran it several times and cycles today at work.
I fixed the elbow about four months ago, and as far as me and the other mechanic can tell, there are no vacuum leaks.
Used carb cleaner and sprayed all around the intake, all the vac lines, etc. No change in rpm or sound.
Old 05-10-2012, 05:15 PM
Also FWIW The plugs are Autolite Platinum. Before that, I used Bosch Iridium, and they was the worst plugs ever for the 4.6L
Old 05-10-2012, 05:22 PM
Quote:
If you have access to a $7k scan tool, it ought to be able to display the Mode $6 date for misfires, cylinder by cylinder. Type "A" misfire data will be misfires per 200 RPMs while the type "B" data will show misfires for each 1000 RPMs. (If its an early version scan tool the mode $6 data will be in hexadecimal, but you can use the Windows calculator to convert it to decimal. If its a fancier scan tool it will convert it to a percentage of misfires per cylinder.)
Old 05-10-2012, 05:26 PM
Yes sir, We used that and everything, and sadly it didn't count any misfires, but We do know its there. And Why would it surge to?
We have seen three other 4.6L's do the same thing, and no one has yet to figure them out.
Old 05-11-2012, 06:57 AM
Hmmmm. Lee says there is a misfire. PCM says there is no misfire. I guess we need a third opinion
What codes did you have before replacing the plugs/wires/packs?
Have you done a compression check on each cylinder?
Can you monitor the fuel pressure when this surge occurs?
Old 05-12-2012, 01:02 PM
Xpdition2000 Xpdition2000 is offline
Xpdition2000 is starting off with a positive reputation.
What coils did you use as replacements? I work in a Fleet dept and we only use the Motorcraft coils because many of the aftermarket coils seem to fail or also create a misfire.
Just recently a co-worker replaced all 8 coils but he used the Duralast brand and after a week of the same symptoms you described, he had them all replaced with Motorcraft coils and the issue/symptom went away.
Old 05-12-2012, 01:14 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Back when I had my 97 Expedition I replaced all 8 COPs with ones from eBay. Those thing ran flawlessly from the day I installed them until the day I traded it in for my Navigator.
Old 05-12-2012, 01:19 PM
I have heard that as well from others about the various brands on Ebay, but when you are servicing Public Safety vehicles you want to eliminate any possible reason for a come back. So we only buy the Motorcraft brand of plugs and coils. They cost more, but save us on come back work.
Old 05-12-2012, 02:47 PM
I see. So my next question is, if the MC plugs and coils are so good, then why did you have to replace them in the first place?
Old 05-12-2012, 02:50 PM
Nothing lasts forever!! ; )
Old 05-12-2012, 04:04 PM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
It would seem you are missing a fuel problem. Try looking to the vacuum first by looking at all vacuum hoses and anything they attach to. Then look to your fuel pressure through out the power usage. Check for a blocked crimped fuel line. You have a mechanical problem or a bad electrical connection, maybe crank sensor. When a pump begins failure sometimes it starves the motor someand then goes away, same with the fuel filter or regulator. See if you have corrosion on the top of your PCM cover. Check the circuit board for obvious burning.
Misfire problem NUKEHEAD1001 1997 - 2003 F150 1 05-11-2016 12:25 PM
Misfiring 4.6L Triton patriot 1997 - 2003 F150 0 04-06-2015 10:44 AM
Misfire F-350 Went724 1999 to 2016 Super Duty 1 09-10-2014 05:53 AM
97 e150 4.6l misfire #2 blacknight79 Modular V8 (4.6L, 5.4L) 3 08-04-2013 08:47 PM
1998 F150 4.6L misfire Arratay 1997 - 2003 F150 4 11-11-2010 10:39 AM
Tags
02, 46, 46l, 97, 98, davidson, expedition, f150, feals, ford, harley, liter, misfire, pcm, time, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
