SD Radiator failed. - Page 3 - Ford Truck Enthusiasts Forums
SD Radiator failed.
  #31
Old 05-21-2013, 07:33 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
Originally Posted by stainlessstroker95 View Post
Travis, how is the silla radiator holding up? Im about to pull the trigger on an aluminum radiator and not sure which on to go with yet. I was gonna get a performance radiator, but they only come with the trans cooler built in. Are the sillas the same way?
Silla was the same way. I pulled the Silla back out as I suspected it was leaking a tiny bit of water. I could always smell hot coolant under the hood when I parked the truck, but never found a leak. Even with the radiator out of the truck, I can see no spots that appeared to leak, but the coolant smell went away with the radiator. It seemed to cool pretty much like the stock radiator did, so that was ok.
I switched to a Mishimoto radiator this time (EXPENSIVE). I'm not sure I would make that switch again with the cost of this radiator, but it sure is pretty. IMO, try out Performance Radiator. That radiator has been recommended in the past by Joey IIRC and that is what I believe to be the radiator that Glenn has.
  #32
Old 05-22-2013, 12:07 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Ya i thought about getting a mishimoto, but figured i dont need one for what i do. I was going to get the performance radiator one, but it has the trans cooler built in to it. Since i have a stick i wouldnt need it. I guess it would be alright to just plug the holes wouldnt it?
  #33
Old 05-22-2013, 07:48 AM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Don't need to do anything.its sealed from coolant.just ignore it.it's
  #34
Old 05-22-2013, 11:15 AM
DarkStarMedia DarkStarMedia is offline
DarkStarMedia is gaining momentum as a positive member of FTE.DarkStarMedia is gaining momentum as a positive member of FTE.
that round sticker on the top of the radiator I thin is for 1800 radiator.... I bought from them before for my jeep...
richard
  #35
Old 05-22-2013, 02:28 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^ Silla is a trusted brand; they make only one of two mass-produced radiators for the old Saturns that aren't doomed to fail right out of the box.
Almost no one makes radiators specifically for manual transmissions anymore. It's cheaper to put the tranny cooler in all the radiators. This has been the trend for 30-odd years.
  #36
Old 05-22-2013, 04:45 PM
Quote:
richard
Never heard of them. I have seen a Performance Radiator brand radiator in person and it looked exactly like Glenn's, but that's not to say two different brands don't look exactly the same. Could probably go either way.
Gabe, all the SD radiators I have used had the trans cooler built into them. I don't need it with my stick either, but it doesn't hurt anything.
  #37
Old 05-22-2013, 04:54 PM
Thanks Aaron and Travis, I think I'm gonna go with th performance radiator brand then.
  #38
Old 05-23-2013, 10:24 PM
fordman67's Avatar
Checck brice thomas radiator.that's quality..made 100% usa.
  #39
Old 05-23-2013, 10:37 PM
Quote:
I ordered the performance radiator the other day. Its the same brand as my intercooler, so they will be a match set. Maybe way down the road il try the mishimoto.
  #40
Old 05-24-2013, 01:12 AM
fordman67's Avatar
I hope their psd rads r better than their mustang...cause they are a waste of alluminum
  #41
Old 05-24-2013, 03:30 AM
I guess i will find out. Its got to be better than the one thats in there now.
  #42
Old 05-24-2013, 08:13 AM
fordman67's Avatar
I meant mishimoto.i think the perf rad wiill be just fine.heck.my parts store job is just fine
  #43
Old 05-24-2013, 11:08 AM
My Mishimoto is fine. outside appearance is absolutely awesome, but that says nothing for what's going on inside the radiator. I run about the same temps as I did with the stock SD radiator honestly.
  #44
Old 05-24-2013, 06:20 PM
fordman67's Avatar
I'm just leery.every mustang I've seen w one leaked.it may have beeen a prpblem that was cured.i don't knoww.but I'm fine with my stocker since my truck is stock.
on a side note.my e fans are finallly all hooked up and working great and the stock alt is now keeping up.woo hoo!
2001 F250 XLT 7.3L Radiator Leak Question cpye2 1999 to 2016 Super Duty 2 03-17-2015 08:03 AM
2 gauge battery charge cable and alternator pigtail write up strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 32 06-12-2013 01:21 PM
Finally got fed up and replaced the radiator! wallster 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-21-2012 06:47 AM
different radiators, shrouds? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 18 07-31-2012 09:36 PM
Electric Fan Install on F-250 - Pics inside 94bonestocker 1987 - 1996 F150 & Larger F-Series Trucks 38 07-03-2012 03:17 PM
Tags
1996, 2wd, 302, 73, 95, aluminum, cheap, ebay, f250, ford, glenns, lightning, oem, performance, powerstroke, radiator, ranger, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
