SD Radiator failed.
Old 05-11-2012, 09:56 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Ya the nipple that goes to the degas bottle broke a long time ago and i just have epoxy holding it on. To get new tanks is 100 bucks but for another 100 you wouldnt have to worry bout it again.
Old 05-13-2012, 02:00 AM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Finished putting my radiator in about 2 hours ago and tested it out. No leaks. I didn't measure it until I was finished, but the OEM SD radiator core measures ~2 1/8" thick and this one is right at 3" thick. Obviously I did have to modify all the bushings farther than I did with the OEM radiator b/c of the extra thickness. I just read through the "limited lifetime warranty" info and it doesn't cover products used for racing. LMFAO
Old 05-13-2012, 08:32 AM
redman84's Avatar
redman84
redman84 is offline
Good thing it went into a street truck eh?!
Old 05-13-2012, 08:47 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Nice looking radiator Travis!
Old 05-13-2012, 01:15 PM
fordman67's Avatar
fordman67
fordman67 is online now
Well at least im not the only one with that dumb thing broke and epoxyd back. Guess i might do something like that someday.i have a dual flexalite fan set up im gonna try out soon.was rated for like 1000hpto supposedly or something.
We shall seel.i will keep following this thread!
Old 05-14-2012, 12:49 PM
strokin'_tatsch
Well so far it's running hotter than it used to. Cruising at 85mph to work today, water was 210* and oil 208*. That is going to bug me. When I slowed down, temps came down to normal. Wonder if this radiator just doesn't cool as well as the stocker. It could be that air coming across the temp probe for the fans is cooling the temp probe enough to prevent the fans from turning on. I'll be checking that out tonight after work.
Old 05-14-2012, 01:47 PM
Talyn's Avatar
Talyn
Talyn is offline
It is a 3 core yes? not a 4 like the stock?
Thats why i hesitate to go to aftermarket. the stock coolers are so beastly.
Old 05-14-2012, 02:06 PM
strokin'_tatsch
I just looked up the part number and it shows to be a 2 row. It also says it's 2 1/8" thick, which is the same thickness as the SD stocker, but mine is right at 3" thick. I"d like to think that there's no air in the system, but I'm going to make sure after I get off work and I'm gonna check out the fans to make sure they are staying on when I'm cruising.
EDIT: I've done some more research and figured out that Glenn's radiator is made by Performance Radiator. Found some good stuff about them.
Old 05-14-2012, 02:08 PM
Talyn's Avatar
Talyn
Talyn is offline
OBS is 4core.
Old 05-14-2012, 02:26 PM
fordman67's Avatar
fordman67
Hasnt he the nbs super duty rad?
Old 05-14-2012, 06:48 PM
oldbird1965
You can tell that by the picture? Good to know its a good one. I think it cools as good as the orginal.
Old 05-14-2012, 06:51 PM
strokin'_tatsch
I looked at all the radiators I could find and that's the only one I could find that had the mounts for the fan shroud like yours. Also, the aluminum caps look like they are crimped on like the factory plastic caps instead of welded like the others I've found. Not saying that's a problem, just the similarity I see between yours and the one from Performance Radiator. Also, the sticker on top of yours looks like the Performance Radiator logo
If this one turns out to be a bust, I may try one of those, one of the Mishimoto radiators, or get one custom made. I don't like the plastic crap. lol
  #28
Old 05-14-2012, 07:03 PM
stainlessstroker95
Good info. Im glad i havent jumped the gun and put an order in yet. And ya fordman67 those nipples dont make good seats haha.
  #29
Old 05-14-2012, 08:39 PM
strokin'_tatsch
Just got home and I think I either have some air trapped under the t-stat or im having t-stat issues. I've been told that the t-stat wont open if there is an air pocket trapped under it. Im not sure as I've never had that problem. All I know is I ran it at 210* for about 30 miles home, got home and the upper hose has tons of pressure. Took the cap off the degas bottle to check the level and of course pressure released. Let it sit and idle for about 10 minutes holding 199-200* and the upper hose wasnt flowing any water. Gonna change the t-stat out to my 180* and see what happens.
  #30
Old 05-21-2013, 06:16 PM
stainlessstroker95
Travis, how is the silla radiator holding up? Im about to pull the trigger on an aluminum radiator and not sure which on to go with yet. I was gonna get a performance radiator, but they only come with the trans cooler built in. Are the sillas the same way?
Quick Reply: SD Radiator failed.
