Need to replace the ends on it. Anyone know of a cheaper place then JBG. Anyone know what ends they use for it. Or do they actually make them special instead of using something from a different vehicle.
For what it's worth the stock stuff uses 7/8-18 left and right hand threads
Thanks. I was using rock auto for reference and it shows a difference between 2wd and 4wd left outer tie rods. If they gave some specs of the tre itself that would help. Bronco graveyard wants $65 for one which I think is a little ridiculous.
I acquired this draglink over the weekend to use on my 79. Turns out they had the ends screwed out pretty much the whole way and one is slightly bent. The joint itself seems nice and tight. I had thoughts about bending it back so I can screw it the whole way back in.
