Ranger or F150 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Ranger or F150
Old 05-10-2012, 11:39 AM
SThornton SThornton is offline
SThornton is starting off with a positive reputation.
Ranger or F150
im thinking about buying a ranger but i would also consider a f150 (300 4 speed) any advice
Old 05-11-2012, 02:19 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
Big truck is safer in an accident. I drove F100/150s for 35 years, all with 4.9L inline six and love that engine, but fuel mileage is poor. I just got a used Ranger 4-banger last Dec and love it, 25 mpg consistently. Feels real nice and sporty being so small. A blast to drive and easy to fit into parking spots. All my F100/150 and Ranger are manual transmission. Always drain out the wimpy ATF from the manual tranny and fill with Redline MTL or a Syncromesh fluid. ATF is too thin.
Old 05-11-2012, 03:34 PM
valdor's Avatar
valdor valdor is offline
valdor is starting off with a positive reputation.
The Ranger certainly is a very usefull and capable small truck. Guess it all depends on need, if need is the determining factor. I finally got a '72 F250 351C V8 last year and love her but she is not practical and gives me 5mpg but that was want rather than need. I know a Ranger would serve me better but.....
Old 05-17-2012, 11:36 AM
Thanks guys Ive decided on a 2.3 liter 5 speed i need better mpg than the 4.9
Old 05-17-2012, 12:57 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Do NOT drain out the ATF and replace it with something else. The trans is designed to have ATF to lubricate it properly, its a given that you replace it every 30,000 - 50,000 miles. The heavier gear oils do not lubricate the transmissions internals properly. The sychros get the worst of it, but the bearings don't care for it much either. I have sent eh damage that the heavier oils do to these transmissions. If it is specced to run Mercon ATF, or MerconV, use the specified fluid and nothing else. Replace it at the manufacturer recommended intervals and the trans will last and shift like it is supposed to. My Dad's '96 2.3L Ranger has 363,000 miles on it currently, and it has no shifting issues using the manufacturer specced fluid (Mercon).
Old 06-04-2012, 11:36 AM
TallPaul's Avatar
Ford dealer service rep approved my running a heavier lube in my M5OD on the '95 F150.
I know you can burn up a splash lubed bearing if too thick but syncromesh approx 30 wt and it is the heavy gear lubes that were the problem. I tried M1 ATF I tried Redline ATF, but it was not until I ran the slightly thicker Redline MTL (not the heavier MT90) that the truck finally shifted nicely. Always shifted notchy until the MTL and that was installed around 150,000 miles, but guess what, with all those miles on the tranny, with the MTL I could shift it as fast as that huge shift lever would let me and never a grind or complaint out of that tranny. Ran that over 40,000 miles and still shifting beautifully.
Way back prob in the 1980s Chrysler speced manual trannies with ATF and there was a "gear rattle" problem. Chrysler's cure? thicker fluid, no more gear rattle.
ranger transmission swap? skrappy 1987 - 1996 F150 & Larger F-Series Trucks 10 09-27-2016 07:52 PM
78 f150 ranger Michael Pace Ford Truck Parts for Sale 0 09-21-2014 09:57 PM
truck emblems brian1080 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-20-2014 12:46 AM
Fuses grizdax 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-10-2011 10:03 PM
SUPER CLEAN TRUCK FOR SALE IN IDAHO 1979 F-150 Ranger Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2002 03:18 PM
Tags
atf, edition, f150, fluid, ford, manual, mixing, mt90, mtf, mtl, ranger, redline, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
