Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-09-2012, 09:35 PM
RNH Performance's Avatar
RNH Performance RNH Performance is offline
Garage is empty, add now
RNH Performance is starting off with a positive reputation.
Slide Pin issue....but not the norm
I started to develop a vibration when using the brakes I've chased it down to the slide pins since I can wiggle the caliper around when tight.
I got replacement pins but it seems they are sloppy in the bushing/ female as well. Do they sell replacement bushings or is there another option?
  #2 (permalink)
Old 05-10-2012, 05:44 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
2000 Ford F-250
Tugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant futureTugly has a brilliant future
I bought two reman calipers for the back - the slide pins were bad and a piston siezed. Fast-forward 7 months and the front calipers have bad slide pins, but I still remember that siezed piston in the back - so remans it is. My truck has a lot of miles and 12 years on it, I feel better that I didn't skimp on the part that stops an 8000-pounds beast, pulling my boat, down a 6% grade. I don't like those "ochitIshoulda" scenarios.
I have no problem with choking the wallet on somethining that makes it go, but might I suggest that you never go cheap on something that makes it stop?
  #3 (permalink)
Old 05-10-2012, 06:18 AM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is online now
2000 Ford F-250
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
You can buy the whole slide bracket that has the female holes for the pins in it at autozone or Ford. My Autozone had them in stock.
__________________
2000 F250 Lariat
7.3, 4R100, 4x4, CC, SB, 4"lift, 315/75/16, AIS, GTP38R, Turbonetics outlet, 4" MBRP, Swamps 200/30 Hybrids, Swamps tunes, Swamps HI V/F IDM, IH bellows, Plenum inserts, Ic boots, OCR, HPx, FRx, Hutch/Harpoon, spin on prepump filter, Bosch pump, DIY 3/8 fuel lines to heads, Autometer boost, trans, pyro, coolant, Isspro EV2 fuel press, ELC, coolant filter, BTS vb, 6.0 trans cooler, Melling LPOP, traction bars, AE and more.
  #4 (permalink)
Old 05-10-2012, 06:33 AM
Not looking at cheap but I didn't see the bushings listed for the slide pins. I was just wondering if I could buy them with out the slide bracket...
  #5 (permalink)
Old 05-11-2012, 04:15 PM
I found I can get new brackets for about $26 my cost through NAPA...so I ordered one.
  #6 (permalink)
Old 05-11-2012, 09:21 PM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER is gaining momentum as a positive member of FTE.
Lets us know if that fixes the problem. I think i may be experiencing a lil bit of the same. I upgraded to cryo rotors and better pads but have recently developed something like you describe. Curious...
__________________
Damon
2001 F250 7.3 CC 4X4, 252k+; ISSPRO EV2 EGT TRANS BOOST, 6637,HPx, FRx, 5" exhaust, BTS VB, DP F5, Door Locks Fix, Cold AC mod, AIH Delete, Bypass Oil & Coolant Filtration;harpoon, Hutch mod, 6.0 mirrors. Coming Soon: Melling LPOP, FluidAmpr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
