WTB 1992-'96/'97 F-series parts - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 05-09-2012, 07:18 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
I need some things to keep up my '97 F350. Mostly small items.
Interior trim needs to be from '95 (or 1994, not sure) and later trucks as colors are slightly different. Mine is called light opal.
1996-'97 gasoline gauge cluster with tachometer
Intact black cluster trim with cutout for dual tanks (nothing on right side)
Right side dash a/c vents
Good (not melted) third brake light/dome light lens w/ screws
Interior dome light lens
Spare tire carrier arm and bolts
Plastic black cover that go over the door underneath driver side door panel
Passenger side mirror with the text "objects are closer blah blah..."
Light grey fuse box cover
Intact rearview day/night mirror
Factory Ford sliding rear window w/ gasket if still good
Also need a nice vinyl bench seat in light grey. Might go cloth or other if it's nice and light grey.
Located within D.C.
PM or reply.
Thanks!
Old 05-09-2012, 10:29 PM
fordka's Avatar
fordka fordka is offline
fordka is gaining momentum as a positive member of FTE.
i got the cluster trim for the dual tanks and has the switch. 2 tabs in the back are broke but should be fin. $10. also got a fuse box cover in blue but could be painted gray.$5. let me know if you want them ill find out shipping.
Old 05-10-2012, 12:18 AM
I'll pass. The same tabs are broken on mine and it doesn't hold up well & rattles.
Old 05-10-2012, 01:53 PM
Sean's 97 F250's Avatar
Sean's 97 F250 Sean's 97 F250 is offline
Sean's 97 F250 is starting off with a positive reputation.
I will sell the interior light lens from my 1997 f250 heavy duty as my light doesnt work (think bulb bad). Take $13 shipped.
Old 05-15-2012, 11:47 AM
Bump, updated list.
Old 05-23-2012, 08:46 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I have the third brake light lens and the dome light lens, but I need a picture of the dome light you have. Seems there were a couple different styles available for our trucks. I also have a grey fuse box cover but it is for a diesel truck so the legend sticker on the inside of the cover may not be the right one for a gas truck. I think I also have the black plastic strip that you want for the rocker panel. You're talking about the piece that runs between the A pillar kick panel and the B pillar, correct? It is a narrow black plastic strip that screws down and holds the carpet in place? If that is what you need, I have that as well.
Old 05-23-2012, 08:59 AM
Also, for what it is worth, the A/C vents are interchangeable for the most part. They just pop out of the dash (I use a pair of putty knives, one on each side). The "fins" or whatever you want to call them can be removed from the louver assembly as well and swapped between vents if you need to repair a couple. I will look for those as well if they will help. I may have parts and pieces of them even if I don't have complete assemblies.
Misc. 1973-1996 F-series and Bronco parts. Fordzilla80 Ford Truck Parts for Sale 3 10-07-2012 11:47 PM
94 F150 interior parts. Green Griffin 420 WTB - Parts & other 15 07-23-2011 01:47 PM
Drivers side mirror lens cover paul100 1999 to 2016 Super Duty 5 01-13-2006 06:00 PM
Factory options, packages and accessories. 81-F-150-Explorer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 08-09-2005 02:53 AM
Interior parts jkiser96 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-10-2000 07:35 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1992, 199296, 9697, carrier, center, dash, diesel, f250, ford, fseries, jumper, mount, seat, tire, trim, truckfseries
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
