Need 1" rear lift - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need 1" rear lift
Old 05-09-2012, 07:00 PM
cbzdel cbzdel is offline
cbzdel is starting off with a positive reputation.
Need 1" rear lift
If you needed 1" of rear lift what is the best way to do it? I can get a 1" AAL or I can get custom rear blocks made.. Or I could possibly get a 1" block and just stack it with my factory block??
I have a 2" leveling kit up front but I also have the plow prep package, so I am sitting about 1" low in the rear..
Old 05-09-2012, 08:40 PM
ttb29's Avatar
ttb29 ttb29 is offline
ttb29 is starting off with a positive reputation.
Take a look at newton lifts
Old 05-10-2012, 05:55 AM
drey04's Avatar
drey04 drey04 is online now
drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.
Don't stack blocks. Either get bigger blocks or the AAL.
Old 05-10-2012, 11:41 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
1" ?
Wouldn't inflating the rear tires additional 15 psi do the trick?
I have strong feeling you need air bags.
Old 05-10-2012, 12:04 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
I thought that you were going to install a new lift kit in the summer... If that is correct, then I wouldn't spend the $$$ on leveling the rear axle. I would put that $$$ toward the new lift kit.
Old 05-10-2012, 12:26 PM
My plan was to lift it this summer, I was going to do an 6" to 8" lift. But ever since I used my truck as a "real" truck, there is no way I would be happy with a lift kit and bigger tires haha.. So now I think I just want to level it out and leave it how it sits now..
But the front is 1" higher than the rear, it looks weird to me and others ask why is the front higher, it has nothing to do with towing its just the leving kit with the combo of the plow prep package, so I would like to raise the rear 1" to even it out..
Old 05-10-2012, 12:37 PM
Furian's Avatar
Ok, then I would replace the rear block and u-bolts. You have many options from the aftermarket.
Old 05-10-2012, 04:36 PM
bigbadgixxer's Avatar
bigbadgixxer bigbadgixxer is offline
bigbadgixxer is starting off with a positive reputation.
measure your rear blocks? its a 250 right? i have larger blocks and want to lower my rear end alittle i have a 2003 f350 lmk
thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
