Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 05-09-2012, 03:35 PM
billbot billbot is offline
2006 Ford F-250
billbot is starting off with a positive reputation.
none none none none none
Dome light for bed cover?
The dome light got broken on my truck bed cover a where while back. I looked around for a good replacement but haven't had any luck. Eventually it got so bad that the bulb was too close to a wire and melted it so I removed the light. It sucks at night not being able to find stuff.
Ayone have a good source for such a light?
  #2 (permalink)
Old 05-12-2012, 07:42 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
Garage is empty, add now
jdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud ofjdadamsjr has much to be proud of
Battery operated led light ?
I got a few for the rv and the batteries have lasted a LONG time...
http://www.campingworld.com/shopping...n-sensor/56786
makes it easier to find the light switches !!!
__________________
13 F-350 Platinum 6.7 CC SB Tuxedo Black Metallic 11.5k gvwr,
13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost Tuxedo Black Metallic.
12 MVP Destiny 355RE 5th wheel
gone-12 F-250 6.7 CC SB Sterling Grey Metallic Lariat w/ Ultimate Pkg. MBRP filter back Exhaust, Airlift air bags.gone-05 Ex 4x4 6L,even goner-2002 4x2 7.3L Ex Limited
  #3 (permalink)
Old 05-12-2012, 09:45 AM
2006 Ford F-250
Ill check it out. Thanks
  #4 (permalink)
Old 05-26-2012, 01:01 PM
Aftrmidnite Aftrmidnite is offline
Aftrmidnite is gaining momentum as a positive member of FTE.
If you have 12 VDC in the Bed I'd used 12 volt LED rope light. I ran it under the Cover Rails. They threw away the Rope light at work after they couldn't get it to work. I plugged it in and had no problem. I bought the adapters and end pieces on-line.
  #5 (permalink)
Old 05-29-2012, 04:30 PM
2006 Ford F-250
Thanks for the replies. I like the rope light idea. My problem is with clearance. Most of the lights hang an inch or two and I'm afraid it will have the same fate as the last one.
Tags
battery, bed, cargo, cover, covers, dome, f250, ford, lighting, lights, make, operated, rope, tonneau, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
