Need help pinpointing cause of noise
This is on a 2008 Navigator EL.... happens on all gears and the noise follows the rpms and is present even at idle, turning, etc etc. Best way to describe the sounds is a whine sound like I have a roots blower underhood. Does this jive with the power steering pump going out? Is it beyond recovery? Will a flush and fill bring it back to life? I'll see about getting a video up and going tonight but curious of what some of the possible culprits could be.
Can't get the audio to play, but here's something to check. It's very common:
Check the idlers on the serpentine belt. They should turn very smooth/quiet but they usually start to get rough/noisy sometime after 50k miles. There are 3. One is the spring-loaded tensioner for the belt, the other 2 are stationary (just an idler pulley with a bolt through it into the block). They each contain a #6203 bearing ($1.50 each) and they can be pressed out/in with a couple of different sized sockets in a vise. Don't hammer them or you'll risk damaging the pulleys. Getting the belt off/on takes a bit of patience but other than that it's a very simple job. Don't let the parts guy sell you the complete idlers. All you need are the 6203 bearings, available at any local parts place.
Hope this helps.
Pilgrim
Hope this helps.
Pilgrim
I should be more clear. I believe it's the fan not disengaging. I had this problem with mine. Sounds like engine is straining and a weed blower is constantly roaring. I finally convinced the dealer to check it with their laptop-it said fan-0ff but it was clearly engaged full time. Swapped out the fan and it problem solved.
Fan Clutch....hmmm I'll check it out. The engine isn't straining at all though and it doesn't have that jet engine is going to suck everything in front of it sound to it at any point in time. Just that annoying constant whine like a roots type blower. I know lots of peeps that pay good money for that kind of noise.... but would prefer the power that comes with it .......
mike's1980f100
11-17-2013 10:41 AM
Tanner2255
09-30-2012 06:41 AM
mrshorty
12-03-2002 06:33 AM
