in bit of a pickle.
in bit of a pickle.
so everything is hooked up and good buttttttt the cable that goes to the starter is in between of the tubes of the headers
so i was thinking of rerouting the wire but where ever i put it the tube will be touching it? so is there anything thing i could use to cover it?
i was thinking this stuff
the bendy tube use for electrical wires? or is there something else i could use?? please help me guys im going to take it to the exhaust shop tomorrow after we hookup the lokar throttle cable and the lokar throttle bracket!
All you need to do is look around the engine bay for a wire that's 12v that goes on and off with the key.
Do NOT, however, tie it into any of the wires that tie into the distributor/ignition module. I did that the first time I wired mine up, since they're easy to find over there, and it made my engine run terribly. Took me a few moments to figure out what happened. Just pulled it back off and spliced the original wire back together and it went back to normal.
I think I eventually tied into the hot wire for the windshield wipers.
This is the issue I run into with how mine's wired. Then again, I usually start it immediately, so I've never been too motivated to change it.
Yeah I shoulda bought one of those but I'm gonna return the one I got from advance and I bought one from napa it's a premium remanufactured I shoulda went with theres in the first place. So this weekend my dad and I are gonna take every thing apart and see if we could get it apart! Hopefully the exhaust and intake gasket is reuseable if not I'm gonna have to buy another one
Ya thats why I chose not to use headers, plus about 3 weeks after doing my exhaust my 1 yr old starter fried itself outside of work which wasn't to bad being as it has a lifetime warranty and I was able to get to it. Alot of the remans don't last as long as the originals so one of the smaller starters would in all honesty be worth the investment.
