adding a third row seat
Hey did you have any luck with this? I have an 08 without third row seat and found one in a junk yard for $350 shipped. I want to make sure I request everything from junk yard to mount and make safe. I believe the seat belts are connected to the rear columns in back and run down to floor board. I'm trying to locate one to look at or find pictures to figure it out. Thanks.
Yes at least the front row has holes for mounting
When I pulled the area apart I saw the mounting holes for the front supports. The mounting pattern didn't make sense until after looking at several pictures. Then I realized that the 60/40 seats chairs have an asymmetrical mounting pattern.
I'm worried about the seat belts but removed the back column plastic and see areas for mounting the seat belt supports. On some pics I see that the roof is also a mounting point. I don't want to have to remove the whole inside top. Would be a pain.
