Fuel filter on '08 Expedition
Dropped off my wife's '08 Expedition EL Limited at dealer this morning for oil change. Maintenance schedule from Ford recommends change of fuel filter at 30K miles, so asked for that to be done as well. When I received a call from garage to let me know vehicle was ready for pickup, the serviceman told me the fuel filter wasn't changed since vehicle "doesn't have one." Is this true? I was a little irked that they charged me $27 for "labor" to change fuel filter. Shouldn't they have known there wasn't any filter before trying to replace it?
The 07-09 Expeditions do have fuel filters. 2010+ models have them built into the fuel tank. I know on my 07 the fuel filter is on the inside of the frame rail right under the driver seat area. It is probably the same on the 08.
So the dealership charged you $27 to find out that your car supposedly does not have a fuel filter??? It might be time to find a new dealership.
There is a tiny barb on the end of the clip that locks it in place. Look at the new filter clips and you will see what I mean. Its a bit like a safety that prevents the clip from falling out. Try squeezing the ends together while lifting the clip up. I use a small screw driver to lift it up. Be gentle or you'll break something.
OEM/Fuel line disconnect set for Ford and GM. Auto Zone will loan you the tool for deposit and credit back when you return it. Their is a valve on the fuel injectors on the drivers side. It is used for checking fuel pressure and relieving it. I just let the fuel come out when pulling apart.
CoachMikeSC
08-15-2015 03:24 PM
06expeiditionMan
1997-2006 Expedition & Navigator
01-17-2013 01:10 AM
MPTonyT
02-02-2011 03:11 AM
