48-52 Ford F1 Stock Brake Pedal Raio - Ford Truck Enthusiasts Forums
Old 05-08-2012, 08:37 PM
ADOR's Avatar
ADOR ADOR is offline
ADOR is starting off with a positive reputation.
I am working on some brake pressure math for the brake system I am working on for my 52 F1. I am not at home or I would just take the measurement my self. Does anyone know the stock Pedal ratio of the F1?
Old 05-08-2012, 10:12 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
Not sure about the original ratio, but I can tell you a couple things. Original master is 1 1/16 bore. original rear cylinders are 1 1/16. I think (guess) the front was also 1 1/16 as well. Most people switching to a dual circuit end up 1" bore (1 1/16 is a[parently rare - lots of 1 and lots of 1 1/8). '72 Mustang is the common part to pick if you are going disc/drum. I stayed drum/drum and went to a master cyl from a E100 van - cardon 10-1485 (fenco M1485). are you building new pedals from scratch? If not, then there should be enough info in the forums to get you good candidates. If you are then just keep it around 6:1 or 4:1 depending on power brakes or manual.
Old 05-09-2012, 12:56 AM
ADOR's Avatar
It's for a disk/drum set up. I upgraded to 12" (technically 11-3/4") Ford truck 73-93 f-100/f-150 rotors with Chevy 71-87 1/2 ton truck calipers (kit).
I am leaning toward manual disk brakes but If my ratio is not going to give me enough pressure and volume I am going to cut out the rest of the stock cross member and install a complete new pedal assy with 7" booster for power brakes.
Old 05-09-2012, 01:22 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Are your rotors 5x5.5 bolt pattern? If so, where did you get them? Do you have a part number? I'm looking for a pair. Thanks.
Old 05-09-2012, 02:16 AM
ADOR's Avatar
Here is the link to the kit I got and the instructions. In the instructions they show you the individual part numbers so you can get replacement parts. The rotors are just stock ford 73-93 f-100/f-150 so yes it still has the full size truck bolt pattern. If you go with the 5x5.5 bolt pattern you get 12" disks, if you choose a smaller bolt pattern you get 11" disks for the same price.
This Conversion Kit uses the following rotors and calipers:
ROTORS:
73-93 f-100/f-150 (or ford equivalent)
CALIPERS:
71-87 gm 1/2 ton truck (or gm equivalent)
bearings and seals:
A2 outer bearings
A13 inner bearings
4148 bearing seals
Kit
1948-56 Ford F-1 and F-100 Truck Front Disc Brake Conversion Wheel Kit 18515
Instructions
48-56 Ford F-100, Disc Brake Conversion Kit (5X5) - Performance Online, Inc
I didn't read ahead on the instructions and didn't realize I had to trim a spot on the calipers down with a grinder. Just a lip that needed to come down just a hair so it would contact the adapter bracket for the caliper. It was a very easy conversion.
Master Cyl Brakes Upgrade??? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 12-26-2016 11:18 AM
Brake power booster and master cylinder in an F1 51PanelMan 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-15-2013 06:43 PM
clutch pedal 52 5 star 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-02-2011 01:01 AM
'52 F-1 Brake question dagwood387 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-28-2010 03:43 PM
hanging brake pedal in a 52 woodyf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 12-15-2009 10:19 AM
Tags
16, 1948, 48, 4852, bearings, bore, brake, conversion, cross, cylinder, disc, f1, fenco, ford, pedal, sill, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
