Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
Closed Thread
  #1 (permalink)
Old 05-03-2003, 06:26 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Autolite/ Motorcraft cfm ratings and general info
These following numbers are for Motorcraft/Autolite carbs. This number can be found on the side of the float bowl, right behind the accelerator pump rod, inside of a circle. The number on the right corresponds with the cfm rating on the left. Thanks to chas1234 for these numbers. The first numbers are the venturi size, the second is the corresponding cfm.
These numbers are for 2BBL carbs only.
Number = CFM
.98 = 190
1.01 = 240
1.02 = 245
1.08 = 287
1.14 = 300
1.21 = 351
1.23 = 356
1.33 = 424
These numbers are for 4BBL carbs, courtesy thrillseeker.
1.08= 480cfm
1.12= 600cfm
and a rare very rare
1.19= 670cfm.
For additional info on Motorcraft and Autolite carbs, check out this site:
http://home.earthlink.net/~bubbaf250...rb/carb01.html
He has a lot of good info on the history of the carbs, performance modifications, and carb operation theory.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
Closed Thread
Tags
108 , autolite , autolitecarbs , autolitemotorcraft , c9lf , carb , carbs , carburetor , carburetors , cfm , ford , motorcraft , numbers , ratings , specifacations
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
